OK so got my live center for my ShopSmith lathe and wanted to do a bit of experimenting. I want to see how small of an object I could turn on this thing. Well one thing that has been in the back of my mind is turning porch posts and newels for a layout building. So I gave it a shot and I am dang happy with how it turned out. I have some very small chisels for turning and I also thought about using an old exacto knife blade. These worked well the chisels roughing it out and the knife turned the fine details and the 150 then 320 sand paper did the larger details. I turned one in cedar and it worked out ok but then swithed to maple and that was much better. A lot more controled removal.
The post scales out 6"X6"x8’ roughly. It would allow for a 36 in high rail and at the top about an 18 inch decrotive piece
The only downside to this and it is a big one is I have no clue how to dulicate it. I don’t think I can make a mini dulicator as the wood flexes to much. One idea I have it so make a template out brass or maybe steel and see if I can make it basically a knife that would cut the pattern all at once.
Not being able to replicate them makes it a show stopper.
