Forums General Reviews
  • Topic: Labelle Plastic Lube $510.72 per quart! Or?
    Back To Topics
    (0 rates)
    • August 24, 2013 5:50 PM EDT
      • Posts
        1,494
      • Thanks
        30
      • Thanked
        20
      That price is possible because cost-aware Walthers has LaBelle on sale at 7.98 vs. the regular price of 9.29.
      OR....
      Try SYNPower by Valvoline
      Full Synthetic
      75W-90 gear oil
      $8.00 per quart
      Refill your LaBelle 1/2 ounce "squeeze" containers.
      Save money with a quart-size of Valvoline?
      That's 64 1/2 ounce fillings in a quart of SYNPower
      The cost for SYN Power per 1/2 ounce is 12.5 cents
      The cost for LaBelle per 1/2 ounce is 7.98  (wow!)
      I called Valvoline and affirmed plastic compatibility. The conversation was punctuated by vocal blast of "What! a company is actually selling 1/2 ounces of oil at 8 bucks a squeeze bottle!"
      Hmmmm.
    • August 24, 2013 7:27 PM EDT
      • Saint Johns, Florida
      • Posts
        4,613
      • Thanks
        532
      • Thanked
        747
      Thanks Wendell. You just let them in on a money maker. Thanks.
    • September 25, 2013 4:42 PM EDT
      • Posts
        1,494
      • Thanks
        30
      • Thanked
        20
      My guess is Valvoline won't package 1/2 ounce containers to compete with LaBelle -- considering the obvious alternative that is known by the hobby customer base. Who else would previously pay that amount of money for such a small amount of product?
    • October 28, 2013 7:34 PM EDT
      • Posts
        1,494
      • Thanks
        30
      • Thanked
        20
      Here's a "post script" on the above:
      For those who use electric drills and other electric hand tools that have a composite shell holding the drive parts -- such as my DeWalt electric drill -- I opened it up and used the Mobil 1 oil to lube the bearings.  As an outcome, the drill obviously operates easier.   The grease that was lumped around the bearing parts had long separated itself from the rotating parts -- the oil didn't. My presumption is the grease used at the factory was a plastic compatible product considering the composite drill construction.
      Wendell
    • November 26, 2013 9:37 PM EST
      • Posts
        1,494
      • Thanks
        30
      • Thanked
        20
       In addition to the Mobil 1 synthetic oil, the Mobil 1 brand synthetic grease works equally well with  plastic wheel journals and motor gears. I have also used Valvoline synthetic grease. I caution using the combination greases, e.g. synthetic mixed with conventional petroleum.
      Wendell
    • March 5, 2014 10:39 PM EST
      • Phoenix, AZ
      • Posts
        74
      • Thanks
        0
      • Thanked
        0
      Wendell,
      About a year or two ago I purchased some Mobil one motor oil and gear grease.
      The oil is  a15w -50 and the grease is just called  "Synthetic Grease"  a purple/violet color.
      Both have worked out very well.  I like the purple grease, because I can watch it cover the gears.
      The oil gives you no sense that it is anything different than regular oil.
      It was more expensive than you spent Wendell.  But i think this over a ten year supply.
      Barry
    • April 12, 2014 6:19 PM EDT
      • Posts
        1,494
      • Thanks
        30
      • Thanked
        20
      Source of  "squeeze "bottles to fill with Mobil 1?
      I have saved the small LaBelle squeeze oil tubes and reloaded them with synthetic Mobil 1.
      Anyone with other sources for these small bottles with a tiny lube-tube attachment?
      Our CVS pharmacy had everything but.
      Thanks,
      Wendell
    • April 12, 2014 8:44 PM EDT
      • Pittsburgh, Pennsylvania
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      The local craft store (Pat Catan's) has small squeeze bottles with a pointed tip, for lack of better term. You can cut the tip right at the end to have a small opening, or a bit further back to have a larger opening. And the caps snap onto the tip
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • April 14, 2014 12:09 PM EDT
      • Saint Helena, CALIFORNIA
      • Posts
        450
      • Thanks
        49
      • Thanked
        113
      A quick search for "squeeze bottle needle oiler" found, for example, these -
      http://www.brownells.com/gunsmith-tools-supplies/shop-accessories-supplies/liquid-squeeze-bottles/needle-oiler-bottles-prod44434.aspx
    • April 14, 2014 1:18 PM EDT
      • Posts
        1,494
      • Thanks
        30
      • Thanked
        20
      Thanks Mark!
      Mark's suggestion for oilers is a bulls-eye!
      Brownells' gunsmith tools and supplies has them (see his citation above) at $7.95 for three screw-top, 1/2 ounce bottles with the fine application tube on each screw cap.
    • October 15, 2014 1:16 PM EDT
      • Posts
        1,494
      • Thanks
        30
      • Thanked
        20
      Viola! Here's a way to apply synthetic grease (Mobil 1 or other brands) in small quantities:
      Place a small amount of the grease from the product can into a heavy duty plastic sandwich bag -- the Zip-Lock brand Freezer bag is a choice.  Then, make a very small cut in the corner of the bag for grease application -- the process looks ike a cake frosting application bag.
      Wendell
    • December 19, 2015 5:54 AM EST
      • Ottawa/Nepean, Ontario, Canada
      • Posts
        4,791
      • Thanks
        249
      • Thanked
        364
      This "THREAD" should become a permanent one and should not be lost......if someone can arrange that....please do.
        Fred Mills
    • December 19, 2015 10:33 AM EST
      • Sylvester, Ga
      • Posts
        472
      • Thanks
        9
      • Thanked
        24
      If you know anyone who is Diabetic - they may give you a syringe.  I'm diabetic and use them for oiling models and also in my clock repair hobby.  they are small and you can really control the amount of oil and where it is placed.
    • December 19, 2015 11:33 AM EST
      • Posts
        450
      • Thanks
        49
      • Thanked
        113
      If you don't have ready access to a medical grade syringe then search for "dispensing syringe" or "oiling syringe", lots of choices.
    • December 19, 2015 12:14 PM EST
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      I have a few of those. They are really good for putting a small drop, right where its needed. I did grind the tip of the needle to a blunt end, for safety sake. There used to be a medical supply company near where I live, that sold items like scalpels, blades, gloves and syringes to the public. I am not sure if that is still allowed or if the company is still there.
      Shannon car Shops
    • December 21, 2015 5:24 PM EST
      • Posts
        1,494
      • Thanks
        30
      • Thanked
        20
      Thank you Fred for your suggestion to preserve the data on inexpensive lubrication.
      Here's an upgrade, or summary, of the data I collected:
      1 - The fully synthetic motor oils work on plastics as well as oils used in the food industry. It so happens, the most available to us are the motor oils -- Mobil One motor oil is most cited along with their Mobil One Synthetic bearing grease. There are other choices.
      2 - Thanks to Mark Hadler's contribution (above post), one excellent application method is using the 1 ounce "Needle Oilers" sold by Brownells @ $11.99 for a package of three. They are easily filled with synthetic oil. The closest comparison are the LaBelle oilers. The part number for the oilers at Brownells is 084-000-127WB. Just Google Brownells and fill in the "search" box with "needle oilers". I ordered three sets - a late Santa delivery for several committed LGB oil users.
      3 - Be sure whatever product you use is fully synthetic - which translates as plastic compatible. Again, I use the 15/50 weight Mobil One because it appears to have stick-to-it capacity on the wheel axle ends and on the internal gear shafts within the motor assemblies - that also includes a small drop of oil on the shaft exiting the motor housing to lube the sleeve bearings on the motors.   The gear teeth get the grease.
      Please continue to report your experiences.
      Thanks,
      Wendell
      This post was edited by Wendell Hanks at December 21, 2015 8:06 PM EST
    • December 21, 2015 8:06 PM EST
      • Deer Park, Washington
      • Posts
        12,596
      • Thanks
        603
      • Thanked
        385
      Bump
    • December 21, 2015 8:36 PM EST
      • Posts
        14,947
      • Thanks
        2,901
      • Thanked
        1,694
      Just in case it wasn't mentioned ....KY make a great synthetic lubricant that is plastic compatible and has been approved by the FDA as food industry safe!
    • December 21, 2015 8:38 PM EST
      • Post Falls, Idaho
      • Posts
        8,286
      • Thanks
        2,374
      • Thanked
        1,326
      What are we to do with you. Damn near spit whiskey through my nose.
    • December 21, 2015 8:43 PM EST
      • Posts
        14,947
      • Thanks
        2,901
      • Thanked
        1,694
      But it's the truth?
      Prove me wrong!
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
