Forums Modeling O / On30
  • Topic: Corrugated Roofing
    Back To Topics
    (0 rates)
    • December 26, 2019 12:44 PM EST
      • Post Falls, Idaho
      • Posts
        8,284
      • Thanks
        2,370
      • Thanked
        1,318
      Corrugated Roofing
      I know i can buy commercial corrugated roofing materiel in O scale but I am wondering about a DIY version like we do with pop cans and paper crimpers. Would it be glaringly unreasonable to use the same in O scale. It seems smallish for Large scale anyway but is it going to look huge in O. Is there another way?
      I thought about making a jig to burnish it into foil. I don't want to re invent the wheel. What are others doing in O.
    • December 26, 2019 1:02 PM EST
      • Vail, Az
      • Posts
        5,439
      • Thanks
        1,982
      • Thanked
        1,368
      I went the other direction in the 16' car contest (MIK) I used copper standing seam O scale roofing.
      Seems like one could fold foil over battens to make a scale standing seam roofing. I think the mental image of corrugated roofing is too burned in not to see the over sized bends....
      When I was in On3 I bought the available ...
      John
    • December 26, 2019 3:01 PM EST
      • Post Falls, Idaho
      • Posts
        8,284
      • Thanks
        2,370
      • Thanked
        1,318
      I have thought of doing standing seam. I know how to make that just a saw kerf in a board will work. Maybe thats the route I will go. I agree the size is gonna be glaring I think.
    • December 27, 2019 5:12 AM EST
      • Bundaberg, Queensland Australia
      • Posts
        445
      • Thanks
        13
      • Thanked
        130
      A friend made O scale corrugated iron using smoothed out aluminum foil baking/BBQ trays.
      He made a bender and the "iron"by;
      • gluing Bamboo skewers (you could use dowel) onto 2 wooden frames
      • then sandwiched the foil between
      • then just pushed down to create the corrugations to make the "iron".
      This is similar to what I do with my paper crimper for my G scale iron.
      Trying to describe the frames imagine a 6"x 3" rectangular wooden frame which has grooves cut into it that accept the skewers, the skewers are glued into the grooves bit leaving them proud.
      To make the grooves clamp the 2 frames together and drill holes that same diameter as the skewers and you will end up with semi circular grooves that will leave the skewers proud by the radius of the skewer.
      Hopefully I have describe this so that you may understand, its simple, cheap and an easy way to make "corrugated iron".
      I might even use this method for my indoor HO layout just reducing the size of the skewers by half (HO= Half O)
      Sadly my friend passed away from cancer, but I am using all his HO track work for my indoor layout with his widow's blessing.
      This post was edited by GAP at December 27, 2019 12:36 PM EST
    • December 27, 2019 12:33 PM EST
      • Post Falls, Idaho
      • Posts
        8,284
      • Thanks
        2,370
      • Thanked
        1,318
      So here is what I came up with. Using heavy duty aluminum foil and a jig I made out of some scraps of corrugated styrene sheet I had. Trim the foil to width (3/4") and then just place it on the jig line up the little slider with the grooves in the base and run it back and forth a couple times. Take it off and use the side of the jig to trim to length 3". Makes a 36" by 12' panel.
      The side for trimming length has a groove cut in it to guide the knife. Works pretty slick.
      This post was edited by Devon Sinsley at December 28, 2019 11:44 PM EST
    • December 27, 2019 12:57 PM EST
      • Farmington, New Mexico
      • Posts
        2,578
      • Thanks
        22
      • Thanked
        640
      Trim to length first, that way you don't mess up the corrugations when cutting.
      New Mexico­ Northern ­Railroad
      D&RGW ­315 Crew ­member, Fireman
      RRR #4
      Board Memb­er, Durang­o Railroad­ Historica­l Society
    • December 27, 2019 1:03 PM EST
      • Easton , Massachusetts
      • Posts
        4,639
      • Thanks
        2,267
      • Thanked
        648
      Just pop them back into the jig ...
      This post was edited by Sean McGillicuddy at December 27, 2019 1:04 PM EST
       My u-tube  My Vimeo
    • December 27, 2019 1:06 PM EST
      • Post Falls, Idaho
      • Posts
        8,284
      • Thanks
        2,370
      • Thanked
        1,318
      I tried that and it made it hard to hold onto. With them long I have a piece to hold and smash and ruin and then when trimmed it came out nice. I will play with it and refine the technique I am sure.
    • December 28, 2019 12:19 PM EST
      • Vail, Az
      • Posts
        5,439
      • Thanks
        1,982
      • Thanked
        1,368
      Bill, It would need to be annealed to dead soft to overcome spring back.
      I don't think an annealed shim would wear well.
      John
    • December 28, 2019 7:56 PM EST
      • Post Falls, Idaho
      • Posts
        8,284
      • Thanks
        2,370
      • Thanked
        1,318
      I have thought about using it in G but for my little jig and O scale I am not real sure how that would go. I do want to play with real steel in the Fiskers crimper and see what happens.
    • December 28, 2019 8:10 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Devon, I’ve used steel shim stock in the fiskers crimper with good success. I’m not sure of the thickness currently, I think it’s .002. I’m out of town at the moment so I can’t check. I last used it on the cookhouse I built in the Mik challenge in 2018.
      Edit: I checked my order history with McMaster Carr and it is in fact .002 steel shim stock.
      This post was edited by Dan Hilyer at December 29, 2019 4:07 PM EST
    • December 28, 2019 8:19 PM EST
      • Posts
        14,851
      • Thanks
        2,806
      • Thanked
        1,642
      You will be modeling Amtrak before long !
    • December 28, 2019 11:55 PM EST
      • Pleasanton, CA
      • Posts
        1,189
      • Thanks
        1,388
      • Thanked
        927
      Devon: I use steel shim (.003 I think) with the crimper and then rust it with muriatic acid and hydrogen peroxide. stop the rust with matte clear coat. Learned how to do this from Dennis Rayon [link].
      Here's what his looks like:
    • December 29, 2019 12:30 PM EST
      • Ormond Beach, Fl. 32174
      • Posts
        1,135
      • Thanks
        3
      • Thanked
        540
      So, Jim would the one shown in previous post be too thin? .0015
    • December 29, 2019 12:55 PM EST
      • Pleasanton, CA
      • Posts
        1,189
      • Thanks
        1,388
      • Thanked
        927
      Sorry, Bill, I have no experience with other thicknesses of shim stock. I do admit that I am a bit disappointed in the depth of the corrugation I get with the .003 so it may work better at .0015.
      fwiw, here's a couple of pictures of some roofing after a couple of years outside:
      As I mentioned, the corrugations aren't that deep. fyi: a lot of the bending and other damage is because the wind keeps blowing my roofs off, as I haven't attached them yet due to a long overdue lighting project.
      ok, back to Devon's topic... sorry to hijack...
    • December 29, 2019 1:42 PM EST
      • Posts
        1,135
      • Thanks
        3
      • Thanked
        540
      after looking at your picture maybe the .0015 would be a little thin, I've done coke cans before but never steel and was just looking for something that looked a little more real the aluminum is hard to paint and have look good, Bill
      sawmill
    • December 29, 2019 2:02 PM EST
      • Posts
        1,135
      • Thanks
        3
      • Thanked
        540
      after reading that I guess I wont be using the wife's oven anytime soon, thanks for the lesson, Bill
    • December 29, 2019 3:09 PM EST
      • Vail, Az
      • Posts
        5,439
      • Thanks
        1,982
      • Thanked
        1,368
      Hmmm wonder if all y'all will want to rent oven time?
      John
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
