Forums Vendors and Manufacturers Ads and Announcements Remote Control Systems
  • Topic: New, simplified PnP adaptor.
    Back To Topics
    (0 rates)
    • October 1, 2018 7:31 PM EDT
    • (Moderator)
      • Posts
        3,934
      • Thanks
        0
      • Thanked
        64
      Now available from RCS is a new Plug'n'Play adaptor for battery only conversions of any Large Scale Bachmann and Aristocraft locos equipped with the standard PnP socket.
      It can be used with any non PnP R/C control equipment.
      The # BATTERY-PnP is a plug in pcb pre-wired for plug in VIPER ESC using JST connections, Forward and Reverse lighting and battery + & - connections for the loco electronics.
      INSTRUCTIONS PDF
      This will be an easy way of converting the soon to be released updated Bachmann Annie, that will have a PnP socket fitted.
      The kit with instructions will sell for A$ 19 and will be given away with the RCS EVO -VIPER ESC package deals for those that can use them.
      Best wishes,
      Tony Walsham
    • October 2, 2018 2:26 PM EDT
      • Fort Myers Beach & Annapolis, Florida & Maryland
      • Posts
        2,279
      • Thanks
        72
      • Thanked
        347
      Nice product Tony, and thanks for answering my question about the Viper ESC that I was given.  (It is a 12V and I wondered what it will do with a 14.4 Li-ion battery.  Your website says they work up to 15V and get erratic with a fully-charged 16V Li-ion pack.)
        Pete
    • October 2, 2018 5:43 PM EDT
    • (Moderator)
      • Posts
        3,934
      • Thanks
        0
      • Thanked
        64
      Thanks Peter.
      I do have a Bachmann LYN derivative running on a 4s (1,500 mah) pack and a VIPER without any problems. So it seems it varies a bit.  Could be the protection pcb's I have fitted allowing a bit too much voltage out on some packs Master Instruments make for me.
      The easy peasy solution to over voltage for the VIPER-10-12 volt causing erratic behavior is a couple of 3 amp silicone diodes in series to drop the battery voltage by about 1.5 volts.
      They must be after the charge circuit and before the VIPER.
      A much better all round solution would be if MTroniks could make them to withstand a little bit more voltage.
      Best wishes,
      Tony Walsham
    • October 2, 2018 7:35 PM EDT
      • Elverta, CA
      • Posts
        394
      • Thanks
        3
      • Thanked
        58
      Nice gadget Tony... Simplicity is often grand!
      A 14.4V or 4S Li-Ion battery typically measures 16.8V off charge.... Under significant load, voltage will decay quickly. That said our loads aren't typically more than a few amps, as the battery is consumed voltage degradation ensues and the battery will cruise around 15.0V all the way to recommended voltage cut-out. NOTE: "recommended cut-out" is not until the battery stops working... There are lots of 18650 Li-Ion discharge graphs available online for those interested.
      Michael
    • October 2, 2018 10:15 PM EDT
    • (Moderator)
      • Posts
        3,934
      • Thanks
        0
      • Thanked
        64
      Hello Michael.
      Thanks for the information.
      The problem is not really the batteries.
      The VIPER specs are for 12 volts nominal.  Great if you can fit 10 x NiMh or NiCd cells in a pack. They can handle 15 volts actual, but not 15.1 volts actual.
      In all other facets the VIPER ESC's are terrific. Low cost, prewired with JST plugs and sockets and a genuine 6 amps if needed.
      They are potted and waterproof, so are not user serviceable, but I have yet to blow one up.
      Best wishes,
      Tony Walsham
    • October 3, 2018 12:26 PM EDT
      • Posts
        2,279
      • Thanks
        72
      • Thanked
        347
      Looks like I will just have to try it. . .
        Pete
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
