C21 throttle
Good evening guys
I am wanting to change the throttle control on my Accucraft C21 from a crank and rod connection from the servo to a chain drive to enable wider throttle openings. Some while ago Dwight Ennis posted just such a conversion on MLS but the archive with the article in it is unobtainable. the loco performs well and with the fitted chuff pipe the exhaust sound is very good. Has anyone on this forum a copy of the article or any information on it. I can work out a system for myself but taking advise from someone who has already done the conversion would be a better option.
Regards
David
If you had the URL for the article, you might be able to use the Internet Wayback Machineā€¦
Or maybe you can contact Dwight directly?
