Jack’s been busy replacing all the track that Irma ate, and it is now in good shape. I took the little gons and flats over for a run whiled he replaced the shade cloth on the trellis.
My boxcab decided not to work (another broken wire) so I borrowed the LGB 0-4-0 to test the outer loop and then pull my gondolas and flats. (The flays will be converted to hoppers in a few weeks, hopefully.) That loco is big - I’d say more like 1:19th scale than 1:22.5 ? The field railway cars are similarly large. Fine with me.
This is the bridge over the waterfall (between the hot tub and the pool.)
Then out came Otto, one of my vertical boiler live steamers. He did the usual stalwart job until the water ran out. The flats were put away and I ran with just the gons. Both driver and brakeman are 1:19th scale (Bachmann Europe.)
