Forums General Reviews
  • Topic: AnyRail
    Back To Topics
    (0 rates)
    • June 8, 2016 2:48 PM EDT
      • Post Falls, Idaho
      • Posts
        8,286
      • Thanks
        2,374
      • Thanked
        1,326
      AnyRail
      I was messing with Anyrail today trying to figure out the total footage of track i am working with. It asked me to update AnyRail so I did and the newest version is quite cool. It now has a 3D view which looks like it will be fun to play with. This maybe enough to push me over the edge to purchase the full version.
      I like the program anyways for layout design and although I haven' really explored it yet look like it is even better now.
    • June 9, 2016 8:06 AM EDT
      • Easton , Massachusetts
      • Posts
        4,664
      • Thanks
        2,314
      • Thanked
        662
      Devon
      Once you start laying track ... If you ever do .. It's so different than design .. You might even change some things once you SEE your design!
      PS I think this AnyRail is for Butt modelers!
      This post was edited by Sean McGillicuddy at June 9, 2016 8:08 AM EDT
       My u-tube  My Vimeo
    • June 9, 2016 9:15 AM EDT
      • Post Falls, Idaho
      • Posts
        8,286
      • Thanks
        2,374
      • Thanked
        1,326
      Sean,
      I have every expectation that what I modeled in AnyRail and what will actually get laid down will be different. In fact I know this for certain because there are almost no small sidings in my track plan that I will add on the fly. But what AnyRail did do for me was help me conceptualize and understand what can be done, if only basically, within my space. It helped me "see" it. It also helped me see just how much track I would need. I would not have come close on a guess for how much track I am putting down. Wouldn't have thought it was possible.  Things like grade and grade separated crossings were ease to understand.
      So while I know what I put down will be different and even change over time. I bet I build it very close. It also let me "build" my railroad several times as my ideas developed to see what would work and what wouldn't.
      Its a great planning tool. Its not the end all, but those of us planners its a fun tool. And it is for butt modelers. I have sat on my butt a lot working with it.
    • June 9, 2016 4:48 PM EDT
      • Pittsburgh, Pennsylvania
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      Careful Devon. You have a ways to go, to a bonafide Butt Modeler like me.
      You gave me the title, and I wear it with pride.
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • June 9, 2016 6:36 PM EDT
      • Post Falls, Idaho
      • Posts
        8,286
      • Thanks
        2,374
      • Thanked
        1,326
      I just want to emulate my hero, not take his title of "King Butt Modeler"
    • June 9, 2016 7:28 PM EDT
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      Oh now I am a King Butt Modeler? I have been called a big a$$ before, but not in such a creative way. LOL
      No harm, no foul.
      Shannon car Shops
    • June 10, 2016 12:53 PM EDT
      • Deer Park, Washington
      • Posts
        12,596
      • Thanks
        602
      • Thanked
        385
      Like Eisenhower said, or maybe it was Sun Tsu, no plan survives first contact.
      I've developed all manner of plans, none of which I've used.  Its kind of like a Chinese restaurant, one from column A, two from column B.  Some of this, some of that.
      Make your plan, save it, start with a clean slate, make another, then another, then another.  When it comes time to finally lay track, you'll have a vast library of ideas to draw from.  That's my take on it. Your mileage may vary.
      This post was edited by Steve Featherkile at June 10, 2016 12:55 PM EDT
    • June 10, 2016 3:01 PM EDT
      • Post Falls, Idaho
      • Posts
        8,286
      • Thanks
        2,374
      • Thanked
        1,326
      Well I will be curious in the end to see what actually happens. I tend to be of the "plan the work and work the plan" clan. But I can also see me saying "well let's bend this over there". But in my space I am pretty limited to what I can achieve.
    • June 10, 2016 3:02 PM EDT
      • Post Falls, Idaho
      • Posts
        8,286
      • Thanks
        2,374
      • Thanked
        1,326
      I think I have decided to follow my plan exactly just to spite you guys and prove you wrong
    • June 10, 2016 3:11 PM EDT
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      Devon, I had a plan and I followed it pretty closely. The lower reverse loop had to be "adjusted" to 9.5 foot diameter due to space restrictions. But the rest of it was pretty much what I had planned. Then, yes, then I got larger rolling stock, and the S curve needed to be replaced. That required a reworking of the one end of the upper reverse loop, and a slight raising of the railroad.
      So you could end up following your plan as drawn, but, chances are some adjustments will be made, for one reason or another.
      But, then again, if you never actually build a railroad......
      Shannon car Shops
    • June 10, 2016 4:02 PM EDT
      • Post Falls, Idaho
      • Posts
        8,286
      • Thanks
        2,374
      • Thanked
        1,326
      Oh I do expect adjustments. That's a given I think.
    • June 10, 2016 5:27 PM EDT
      • Posts
        12,596
      • Thanks
        602
      • Thanked
        385
      That's why you build that library.
      This post was edited by Steve Featherkile at June 10, 2016 5:28 PM EDT
    • June 10, 2016 7:11 PM EDT
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      Steve, now you have him building a library, when he should be building a railroad. What's next, a school? A ferry dock? I know, a lighthouse, so you can find your way.
      Shannon car Shops
    • June 10, 2016 7:59 PM EDT
      • Posts
        12,596
      • Thanks
        602
      • Thanked
        385
      If you build it, they will come.
    • June 11, 2016 11:10 AM EDT
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        862
    • June 11, 2016 11:31 AM EDT
      • Pleasanton, California
      • Posts
        408
      • Thanks
        239
      • Thanked
        130
      Devon,
      I used "DannyRail" to design my RR.  I let the lay of the land dictate my layout.  I really never had a had a drawn plan.  I built the RR to fit in our garden working around obstacles and over our Koi pond.  The garden was our first priority with the RR as an enhancement. Take a ride in HD.  Good luck with your plan.
      https://www.youtube.com/watch?v=R-0PPAXE3yQ
      Dan DeVoto
      P-Town & West Side R.R.
      https://www.youtube.com/danstrains
    • June 11, 2016 2:23 PM EDT
      • Saint Johns, Florida
      • Posts
        4,613
      • Thanks
        532
      • Thanked
        747
    • June 11, 2016 3:14 PM EDT
      • Vail, Az
      • Posts
        5,439
      • Thanks
        1,982
      • Thanked
        1,368
      I have a 'vision' of where I'm going, but I am limited by what track I have. That's ok, keeps me from spaghettying my acre of paradise!
      John
      John
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
