Forums General Reviews
  • Topic: B'Mann Track - pass the test of time?
    Back To Topics
    (0 rates)
    • November 24, 2015 11:35 PM EST
      • Posts
        1,494
      • Thanks
        30
      • Thanked
        20
      Have any of you used Bachmann brass track - long enough to make a comparison with LGB, USA,PIKO, etc.?
      Survived a winter? Heat? Ties held up?
    • November 25, 2015 12:37 AM EST
      • Fontana, California
      • Posts
        265
      • Thanks
        9
      • Thanked
        9
      So far after a spring, summer & Fall it has held up great. I'm buying more.
    • November 25, 2015 11:59 AM EST
      • Posts
        134
      • Thanks
        3
      • Thanked
        1
      I didn't like it, I used 3 feet inside a storage building sandwiched between USA and Aristo track. The locomotive stall on the Bachmann section no matter how much the track is cleaned normally near the joint with Aristo track. However if someone can explain this and find a solution for me I would try it.
      Calm Springs Amusement Park(HO Scale) http://www.facebook.com/csamusement Calm Springs Railway(G Scale) http://www.facebook.com/calmspringsrailroad
    • November 25, 2015 6:58 PM EST
      • Pittsburgh, Pennsylvania
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      If its at the joint with other track, it could be dielectric corrosion. Corrosion caused when moisture gets between 2 dissimilar metals. Did you use the so called conductive grease at that joints? Are the Aristo and Bachmann rails touching each other?
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • November 25, 2015 7:15 PM EST
      • Posts
        134
      • Thanks
        3
      • Thanked
        1
      No to the conductivity grease, is that good or bad?
      Yes the rails are touching, joint is good and tight.
    • November 25, 2015 7:29 PM EST
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      Yep, then that's probably what it is. If there was something between the rail ends, so they don't touch, then you would not get dielectric corrosion. If that is what is happening.
      Shannon car Shops
    • November 25, 2015 8:06 PM EST
      • Posts
        134
      • Thanks
        3
      • Thanked
        1
      Interesting since both are advertised as Brass. I also have USA Trains track touching Aristo Brass and Aristo Brass touching Aristo Stainless Steel but the Bachmann/Aristo joint is the only troublesome one.
    • November 25, 2015 9:39 PM EST
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      Well, its just a guess on my part.
      Brass is a generic term for an alloy (usually containing copper and tin). But depending on the mix of those 2 metals, and/or whatever other metals used, different brasses could have different properties. Since you say its seams to always be near the joint with the Aristo track, that would be a likely scenario.
      Disclaimer: I am not a metallurgist, nor do I play one on TV.
      Shannon car Shops
    • November 25, 2015 10:29 PM EST
      • Fort Washington, Pennsylvania
      • Posts
        744
      • Thanks
        7
      • Thanked
        20
      That's interesting.  I hadn't thought of that differing formulaes for brass would have an affect on one-another.  I have noticed that LGB brass track is easier to cut and solder to than Aristo brass track.
      "In the course of my life I have had to eat my words, and I must confess it was a wholsome diet"
        Winston Churchill
    • November 25, 2015 11:43 PM EST
      • Vail, Az
      • Posts
        5,439
      • Thanks
        1,982
      • Thanked
        1,368
      For what it's worth;
      I have a couple of sections of Stainless Steel track that are noticeably gray compared to the rest and they don't conduct like the rest either. Slowing trains drew notice to them.
      Reverse engineering, some supplier gave himself a raise using cheaper ingredients.
      John
      John
    • November 26, 2015 1:41 AM EST
      • Posts
        265
      • Thanks
        9
      • Thanked
        9
      I do not use track pickup so I have no idea how well that works. I'm just going by the overall quality of the track for my large and very heavy K-36 that runs on battery and the track holds up great. Its a very heavy, strong track.
    • November 26, 2015 3:47 AM EST
      • West Grove, Pennsylvania
      • Posts
        11,270
      • Thanks
        896
      • Thanked
        1,306
      But I did stay in a Holiday Inn Express last nite.......................
      "Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." --Martin Luther King Jr
    • November 26, 2015 8:18 AM EST
      • Phippsburg, Maine
      • Posts
        1,138
      • Thanks
        40
      • Thanked
        368
      Brass is copper and zinc.   Bronze is copper and tin.  There are of course differing alloys.  Red brass used for threaded plumbing pipe has more copper.  Some basses have additional ingredients.   Brass also can be soft or hard even with the same chemical composition.   It can be hardened by working it by hammering,  bending or rolling or softened by annealing with heat.
      Our rails are probably extruded like toothpaste from a tube.   Then they are probably rolled to straighten them which would harden them a bit. I suspect they are all made the same way though the details of the process probably differ.   The ratio of copper and zinc in the alloy probably varies a little and the hardness varies a bit too.   I would expect them to play well together.
      They could have a coating of some sort leftover from manufacturing that would prevent good conductivity I suppose.
      This post was edited by Eric Schade at November 26, 2015 8:20 AM EST
    • November 26, 2015 8:56 AM EST
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      Eric, I stand corrected. I told yunz that I am not a metallurgist.
      Shannon car Shops
    • November 26, 2015 8:59 AM EST
      • Posts
        13,786
      • Thanks
        1,518
      • Thanked
        1,123
      CL - What are you using for joiners?  Could that be the conductivity issue?
      www.cvsry.com www.cvsry.com
    • November 26, 2015 9:14 AM EST
      • Posts
        134
      • Thanks
        3
      • Thanked
        1
      Aristo on one rail, Bachmann on the other I believe.
    • November 26, 2015 10:03 AM EST
      • Posts
        13,786
      • Thanks
        1,518
      • Thanked
        1,123
      Thanks. I'm not familiar with the Bachman joiners. Do they use screws like Aristo?  If not, maybe rail clamps at this joint might fix it. The dissimilar joiners may not be making good electrical contact.
    • November 28, 2015 9:02 AM EST
      • Deer Park, Washington
      • Posts
        12,596
      • Thanks
        602
      • Thanked
        385
      Metallurgy is where science meets witchcraft.  Lazarus Long, ca. 2342
      This post was edited by Steve Featherkile at November 28, 2015 9:03 AM EST
    • November 28, 2015 9:47 AM EST
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      Steve, that's alchemy, isn't it?
      Shannon car Shops
    • November 28, 2015 1:24 PM EST
      • Posts
        9,393
      • Thanks
        249
      • Thanked
        862
      I also had a piece of SS that "ran slow" and it was not shiny on the surface but gray.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
