Forums General Articles
  • Topic: A Raised Hybrid Railroad Build Log
    Back To Topics
    (0 rates)
    • October 25, 2015 3:02 PM EDT
      • Maryville, Tennessee
      • Posts
        575
      • Thanks
        34
      • Thanked
        25
      Finally got to start my Garden Railroad while the weather was nice to be outside. Much work has been done.
      I am calling this a Hybrid Garden Railroad as it will be a combination of a above ground filled and also a platform something like Ken Brunt has made. The above ground portion will be on 2x4 joists with a layer of corrugated sheet metal, on top of that will be a layer of screen and then a layer of fabric cloth to hold the soil in place. This area will be about 4-6 inches deep in soil so live plants can be used. The corrugated area will be angled slightly to ensure water will run off and a possible channel add to collect the water and exit the railroad. The area is not level as you can see from the first picture
      The short rails for the curve are cut to 22 1/8" that makes approx 10 foot diameter curve.
      The long rails are 48 inches in length.
      The sub roadbed has not been defined yet.
      The frame work is 4x4 posts and 2x4 rails all pressure treat for ground contact.
      All Rails are square cuts only,
      The posts are cut at angles if needed like on a curve. See pictures for more detail.
       The upper end is only 10 inches high and will be the area  with fill dirt.
      View is what the finished wall looks like before painting. Ran out of 2x4s on the second panel.
      Back side of Panel showing how the rails are attached.  I am using a Kreg Pocket Jig.
      Corner Post has two 1 1/2 inches Dado's 3/8" deep and 3/4" lip. This hides any mis-cuts on the rail ends.
      Post cut for the start of the curve, notice both sides are cut at 11.25 degrees.
      Post cut between two curves sections, both sides are cut at 11.25 degrees.
      Post cut to end the curved section and start of a long straight rail section. The final angle cut had to be determined by using a string from the start to finish of the straight section and a compass used to measure the cut angle, it was about 6 degrees for the right side cut. The left side is just a straight dado cut.
      Post at end of the straight section making a slight left hand jog to parallel the stairs. Angle cut is about 5 degress
      This post was edited by Dennis Cherry at October 30, 2015 10:11 AM EDT
      Dennis in East Tennessee
    • October 25, 2015 11:30 PM EDT
      • Post Falls, Idaho
      • Posts
        8,284
      • Thanks
        2,370
      • Thanked
        1,318
      Well heck I don't know what the railroad is going to look like but if it is anywhere as nice as the post and rail system is turning out then it is sure to impress. I love wood working as much as railroads and the attention to detail is well appreciated. One could have just cut the ends and stuck them to the posts and no one likely would have noticed but the extra working in making the dadoes and angled rabbits to hide the miscuts will give it a very nice clean look. I do have to ask, and not that it would make a spit of difference, but I am wondering why angled rabbits and not angled dadoes?
      Great job.
    • October 26, 2015 4:08 AM EDT
      • West Grove, Pennsylvania
      • Posts
        11,213
      • Thanks
        841
      • Thanked
        1,230
      Looking forward to seeing where this goes!.....
      "Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." --Martin Luther King Jr
    • October 26, 2015 7:05 AM EDT
      • Easton , Massachusetts
      • Posts
        4,638
      • Thanks
        2,266
      • Thanked
        648
      What no mortises and tendons?
       My u-tube  My Vimeo
    • October 26, 2015 8:34 AM EDT
      • Posts
        575
      • Thanks
        34
      • Thanked
        25
      Great job.
      Thought about the angled mortises, but thought that was prone to error and time.
      The angled cuts on the post are easy to do with a table saw and standard 10" blade. If any one is interested on how to make these cuts I can do that.
      This post was edited by Dennis Cherry at October 27, 2015 8:31 AM EDT
    • October 26, 2015 9:58 AM EDT
      • Post Falls, Idaho
      • Posts
        8,284
      • Thanks
        2,370
      • Thanked
        1,318
      I kind of figured that was the answer.
    • October 26, 2015 10:04 AM EDT
      • Phippsburg, Maine
      • Posts
        1,138
      • Thanks
        40
      • Thanked
        368
      This looks like a cool way to build a railway!  I look forward to seeing the progress.
      One suggestion I might make is to box around the house deck posts to keep soil away from them.  This modern pressure treated is not very resistant to rot and it would be a shame to bring down the deck.
    • October 26, 2015 12:48 PM EDT
      • Strattanville, PA
      • Posts
        1,295
      • Thanks
        152
      • Thanked
        153
      Very nice woodworking Dennis,   really looking forward to your progress.  I'll add one more feature to consider.  If I'm understanding correctly there will be a large cavity under the the deck that covers the walled area.  I would add a screened opening  at each end to allow airflow through the bottom.  I could see things getting pretty damp under there and a bad crop of mold growing otherwise.  Keep up the good work.
      forum sig
    • October 27, 2015 8:33 AM EDT
      • Posts
        575
      • Thanks
        34
      • Thanked
        25
      Eric, yer you are correct and still addressing that issue. Do not know what to use to protect the posts. Any thoughts?
    • October 27, 2015 8:39 AM EDT
      • Posts
        575
      • Thanks
        34
      • Thanked
        25
      Good idea, this section runs north and south, will get a few vents added to help the air flow. I do not expect to have any access point as it will be so low to the ground, all the wiring will be buried in the layout.
      As you see from the picture most of this section of the layout is under the deck and does not get wet. only the upper section for about 10 feet does get wet and that part will be fill dirt.
    • October 27, 2015 9:31 AM EDT
      • Post Falls, Idaho
      • Posts
        8,284
      • Thanks
        2,370
      • Thanked
        1,318
      Hey Dennis,
      What about cement board to cover those posts. Screw it in with the right screws that are waterproof grout the edges and then paint on the black tar stuff used to seal concrete foundations. None of it would be expensive and would then form a water resistant barrier. Where the post exits the layout you could do a bit of foam rock scenery of cement scenery to incorporate the post and make a water barrier with a purposeful design.
    • October 30, 2015 10:14 AM EDT
      • Posts
        575
      • Thanks
        34
      • Thanked
        25
      Just added the missing photo to my first post on this topic. This is the first day without rain this week.
      Waiting on my next load of 2 x 4's to fill in the rail sections.
      This post was edited by Dennis Cherry at October 30, 2015 10:14 AM EDT
    • February 8, 2016 11:16 AM EST
      • Posts
        575
      • Thanks
        34
      • Thanked
        25
      Last week I got one day of good weather to work on the Railroad.
      I had to make an inside 4 foot radius curve, so using Sketchup I made a drawing on what was needed, then made a prototype of the post cuts to confirm my settings.
      This went easier than I thought and a couple of hours had the inside curve installed. Right now only had 2 rails between each post and that is to keep the posts in alignment. It really self aligns the post.
      First picture shows looking at the outside face where you can view the railroad.
      This photo is from inside railroad
      Last photo is looking down on the post to show the cuts
      This post was edited by Dennis Cherry at February 8, 2016 11:21 AM EST
    • February 8, 2016 11:33 AM EST
      • Posts
        575
      • Thanks
        34
      • Thanked
        25
      More Pictures of the layout
      Thought I would show more of the construction.
      First Picture show more of the completed 50 foot long wall and the36 inch walkway against the house.
      Second picture is looking from the opposite end  and shows how the layout will go under the steps.
      Third picture shows where the layout will be going. it will stop at the 4x4 laying on the ground and come back to the stake in the lower right hand corner of the picture, there it will make another 4 foot radius turn back to join the layout. The area around the trees will become a garden for my wife, but will also have two large loops of track going over the garden on trestles between the trees.
      Access to the layout will have two walk through's, one is against the house and the other will be on the outside of the layout, the paths width is 36" to make it easy for people to walk.  The inside part will terminate at the steps. This makes the layout a 'U' shapes.
      This post was edited by Dennis Cherry at February 8, 2016 11:49 AM EST
    • February 8, 2016 3:24 PM EST
      • Posts
        13,751
      • Thanks
        1,486
      • Thanked
        1,091
      Nice work Dennis.   Are you back filling inside that wall you are building?  Also, how are you cutting the posts slots; with a dado blade?
      www.cvsry.com www.cvsry.com
    • February 8, 2016 8:28 PM EST
      • Southern Oregon
      • Posts
        1,966
      • Thanks
        514
      • Thanked
        1,019
      Nice precision layout for those cuts
      Are you going to back fill with soil all the way to the top?
    • February 9, 2016 9:58 AM EST
      • Posts
        575
      • Thanks
        34
      • Thanked
        25
      I do not think all will be back filled.  75% might be raised on a platform, still thinking about how and what to use material wise. The upper part only right now will be back filled as this is the lowest part of the layout.
      The posts with the square rabbet cuts are made with a dado blade, not a wobble blade, set to 3/4" x 3/8" deep and three passes are needed. The angle cuts on the other posts just use a standard combination blade. The blade is set to 11.25 degrees for the cuts.  You need a fence of over 3" tall or you have to attach a board to the fence to make it tall enough.
      The standard blade I am using is a Dewalt DW3114 Construction blade 10" 40 Teeth. Got it at Ace Hardware for around $25.00. Have seen them at Lowes also.
      This post was edited by Dennis Cherry at February 9, 2016 9:59 AM EST
    • February 9, 2016 2:24 PM EST
      • Posts
        13,751
      • Thanks
        1,486
      • Thanked
        1,091
      Thanks Dennis.   If I had read back before I asked the questions I would have seen you gave the answers in your first posts.
    • February 14, 2016 7:48 AM EST
      • Southern Illinois
      • Posts
        9,197
      • Thanks
        514
      • Thanked
        514
      Nice Work!
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
