Forums General Reviews
  • Topic: USA's Hudson? Did one get posted?
    Back To Topics
    (0 rates)
    • December 5, 2013 7:44 AM EST
      • Easton , Massachusetts
      • Posts
        4,664
      • Thanks
        2,314
      • Thanked
        662
      Morning
      I looked thru all 12 pages and didn't see a review of USA's Hudson.
      Nick did you wright one up? Could you wright one up?
      Just trying to see what i got myself into?;)
       My u-tube  My Vimeo
    • December 9, 2013 6:18 AM EST
      • UK/Ontario/Oregon
      • Posts
        4,342
      • Thanks
        121
      • Thanked
        87
      Ten years ago you might have gotten a review...............................
      tac
      Ottawa Valley GRS
    • January 10, 2014 9:42 AM EST
      • West Berlin, NJ
      • Posts
        53
      • Thanks
        0
      • Thanked
        0
      Sean,  I've had one since they first came out, haven't had any problems with it. Mine came without the sound system, but the Phoenix system dropped right in, even the smoke chuff worked just fine, there was a wiring change so it would puff correctly. I have seen posts where others have had problems with the smoke generator, but I haven't experienced any.      nick jr
    • January 11, 2014 7:30 AM EST
      • Posts
        4,664
      • Thanks
        2,314
      • Thanked
        662
      Thanks nick.
      I haven't have the chance to Run mine to much yet.
       My u-tube  My Vimeo
    • January 11, 2014 7:38 AM EST
      • West Berlin, NJ
      • Posts
        53
      • Thanks
        0
      • Thanked
        0
      Sean, when you do get a chance to run it,  let me know what you think.     just a tip on the plug that connects the loco and tender.   I use a pair of long nosed pliers to grasp it so the wires don't dislodge from the plug, don't just pull the cable,  fit can be very tight and not much room for fingers.
      This post was edited by Nick Jr at January 11, 2014 7:39 AM EST
    • January 11, 2014 3:43 PM EST
      • Posts
        4,664
      • Thanks
        2,314
      • Thanked
        662
      Isn't that common knowledge??
       My u-tube  My Vimeo
    • January 12, 2014 4:50 AM EST
      • West Berlin, NJ
      • Posts
        53
      • Thanks
        0
      • Thanked
        0
      Evidentially not to all,  at least two posted pulling the plug off due to the very tight fit of the socket and the small space to grasp the plug.
    • January 12, 2014 5:02 AM EST
      • West Berlin, NJ
      • Posts
        53
      • Thanks
        0
      • Thanked
        0
      Sean, I found on Google that Garden Railways March 2006 had a review of the USAT Hudson.   If someone has that issue maybe they can help you more.
    • January 12, 2014 3:34 PM EST
      • Posts
        4,664
      • Thanks
        2,314
      • Thanked
        662
      Nick
      Do you use Aristo's x-wide switches, did you have a problem with the Hudson going thru them?
       My u-tube  My Vimeo
    • January 13, 2014 5:15 AM EST
      • West Berlin, NJ
      • Posts
        53
      • Thanks
        0
      • Thanked
        0
      Sean, I had no trouble with the wide 10' diameter 203 series switches both forward and reverse.
    • January 13, 2014 5:27 AM EST
      • Posts
        4,664
      • Thanks
        2,314
      • Thanked
        662
      My tenders trailing truck likes to jump the track.
       My u-tube  My Vimeo
    • January 13, 2014 7:59 AM EST
      • West Berlin, NJ
      • Posts
        53
      • Thanks
        0
      • Thanked
        0
      I haven't herd of that one, and I'm sure you checked all of the obvious.  Hopefully some one will read this and chime in.     Let me know if you want to compare any measurements of the truck.    Good Luck
      This post was edited by Nick Jr at January 13, 2014 11:17 AM EST
    • January 13, 2014 5:37 PM EST
      • Cumming, GA
      • Posts
        1,055
      • Thanks
        10
      • Thanked
        21
      Might want to check the gauge of the wheels on the tender.  Later RJD
    • January 14, 2014 4:45 AM EST
      • Posts
        4,664
      • Thanks
        2,314
      • Thanked
        662
      HHHmmmmmmmmmm ;)  I'll definitely give that a look see!
      This post was edited by Sean McGillicuddy at January 14, 2014 4:46 AM EST
       My u-tube  My Vimeo
    • January 14, 2014 5:53 AM EST
      • West Berlin, NJ
      • Posts
        53
      • Thanks
        0
      • Thanked
        0
      Since you have so much 'common knowledge',  I assumed that would have been the first measurement you had checked.
      This post was edited by Nick Jr at January 14, 2014 10:49 AM EST
    • January 14, 2014 11:03 AM EST
      • Posts
        4,664
      • Thanks
        2,314
      • Thanked
        662
      Since you have so much 'common knowledge' ( Known to fade once in a while!!)
      OK
      I took the time to really look @ the tender. The back truck is being hindered from full side to side movement  by the V looking thing that goes over the Kadee box.
      This piece is attached with 2 screws. I removed this piece( That is what the hoses etc. are attached to). I will not or any one on my railroad will notice it missing. Charlie Brown asked if it is needed to pull freight . Nope Kadee will do all the work! Let it go then, put it were we can find it if it is needed later!
      If the rain stops today, I might get a chance to put the Hudson thru some more testing.
      This post was edited by Sean McGillicuddy at January 14, 2014 11:04 AM EST
       My u-tube  My Vimeo
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
