  • Topic: AZARR antenna for brass K-28
    Back To Topics
    (0 rates)
    • January 25, 2009 9:30 PM EST
      • Posts
        3,966
      • Thanks
        1
      • Thanked
        90
      Getting decent range with R/C in brass locos has always been a problem with most brands of R/C. I have tried many ways including a simulated coal rake laying across the coal load, connecting the antenna to the track and stringing it around the edge of the load. Nothing worked really well. I have just finished installing battery R/C and Phoenix sound in an Accucraft K-28 for a customer and thought I would try another approach. The AZARR 27 MHz Lite antennas give fantastic range in plastic locos BUT, the base of the antenna (the thick part in the pics below) MUST be mounted vertically for the best results. I needed to have the antenna removable so I had to make a plug and socket for the tender coal load. Here is how I did it.
      The top antenna is the standard "as it comes" AZARR. Below it is with the smallest K & S brass tubing I could find soldered to the exposed AZARR wire.
      The text in this pic should be self explanatory.
      Here is the antenna plugged into the home made socket. The socket can still be seen because it was not yet darkened.
      Once darkened the antenna base is barely visible. 6' feet away and it is invisible. The actual antenna wire is so thin it can barely be seen against any sort of garden background. During testing I could not get any further away than 200'. I have no doubt it would work flawlessly at greater than 200'.
      Best wishes,
      Tony Walsham
    • January 26, 2009 8:46 AM EST
      • Bartlesville, Oklahoma USA
      • Posts
        3,355
      • Thanks
        4
      • Thanked
        28
      I think that's the one we call "be-cubed" in the states. I like mine. I painted it black before noticing in the instructions, "Do not paint," but it works very nicely.
      In that awkward stage between preschool and death.
    • January 26, 2009 10:03 AM EST
      • Posts
        3,966
      • Thanks
        1
      • Thanked
        90
      Tom.
      The AZARR antennas are made by E-Cubed R/C in the USA. AZARR is the name of the maker.
      You can order them all black.
      As the tender shell is plastic, you could actually put yours in the tender shell. As long as the thick bit is vertical the antenna wire can be put around the inside top of the tender body.
      Just keep it as far as possible from the batteries and speaker magnet.
      Best wishes,
      Tony Walsham
    • January 26, 2009 2:53 PM EST
      • Posts
        3,355
      • Thanks
        4
      • Thanked
        28
      Actually, the sound board is sticky-taped to the back of the tender on the inside. Bet it'd work better if I...
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
