Forum Sponsorsss
Forums General Track and Trestles
  • Topic: STARS build log: Installing on a slope
    Back To Topics
    (0 rates)
    • July 6, 2020 10:34 AM EDT
      • Tiburon, California
      • Posts
        323
      • Thanks
        11
      • Thanked
        10
      Since the South Tiburon and Raccoon Straits RR will be using a fair bit of elevated railway, I thought I'd post it here.  This will start out as a basic dogbone, with both turnaround loops extending over sloped grade, and will need elevation to attain a reasonable grade for the trains.  Since this is a sightseeing and logging line, I can accept a little more steepness, but not a lot, of course.  Stage 1 will be some experimenting.
      In that vein, the first step is the Western loop: a simple loop made of redwood fence boards that will be supported by.... something...
    • July 6, 2020 12:25 PM EDT
      • Denver, Colorado
      • Posts
        2,317
      • Thanks
        362
      • Thanked
        678
         Sweet. Keep us posted for sure.
    • July 6, 2020 1:01 PM EDT
      • Vail, Az
      • Posts
        5,439
      • Thanks
        1,982
      • Thanked
        1,368
      I love a well thought out something! Should be fun!
      Don't wear out your engines on steep grades. We have no repair parts.
      John
    • July 6, 2020 1:03 PM EDT
      • Posts
        323
      • Thanks
        11
      • Thanked
        10
      Boy, that's a good point.  I had not been thinking about wearing out the engines.  So yeah, just because it "can" doesn't mean it "should".
    • July 6, 2020 7:51 PM EDT
      • Chaco, Paraguay
      • Posts
        2,757
      • Thanks
        348
      • Thanked
        347
      i have achieved 6% (1 in 17) grades with short, heavy locos, motorized tenders, additional weight and only five short cars.
      but on my next layout there will be nothing steeper than 3 or 4%.
      My Chaosplace ->
    • July 6, 2020 9:23 PM EDT
      • Southern Oregon
      • Posts
        1,972
      • Thanks
        525
      • Thanked
        1,034
      The flatter you can keep the railroad the better the operation period.
      Unless there is a specific reason for grades (as in my case, trying to keep everythig at a reasonable height above ground)
      everything should be dead level.
      Just my opinion
      Rick
    • July 9, 2020 11:45 AM EDT
      • Posts
        323
      • Thanks
        11
      • Thanked
        10
      Track laid out to see how the loco will run... hoping I can get away with a 6% grade.
      This post was edited by Michael Moradzadeh at July 10, 2020 8:07 PM EDT
    • July 9, 2020 1:14 PM EDT
      • Vail, Az
      • Posts
        5,439
      • Thanks
        1,982
      • Thanked
        1,368
      Don't worry, I see a thin rock quarry off to the right so you might raise your bottom!
      John
    • July 10, 2020 7:41 PM EDT
      • Posts
        323
      • Thanks
        11
      • Thanked
        10
      Some trestles.  My first ever
    • July 10, 2020 11:07 PM EDT
      • Vail, Az
      • Posts
        5,439
      • Thanks
        1,982
      • Thanked
        1,368
      Nice, those are 'bents'.
      John
    • July 11, 2020 8:35 AM EDT
      • Chaco, Paraguay
      • Posts
        2,757
      • Thanks
        348
      • Thanked
        347
      when you know the exact hight, it might be usefull, to add another horizontal beam as footer.
      My Chaosplace ->
    • July 11, 2020 10:49 AM EDT
      • Posts
        323
      • Thanks
        11
      • Thanked
        10
      Bents.  Got it.  and yes, a footer makes good sense.
    • July 31, 2020 10:42 AM EDT
      • Posts
        323
      • Thanks
        11
      • Thanked
        10
      Steam-bending loop
      For the western loop, I decided to try steam-bending.  After a fair degree of trial and error, I think I have it.  1/4" redwood lath, ripped to 1" wide, steamed for two hours, can bend into a 6'radius circle.  Glue-up is setting in the garage with two strips laminated for each rail (pic to follow)
    • July 31, 2020 10:54 PM EDT
      • Posts
        13,754
      • Thanks
        1,489
      • Thanked
        1,095
      Years ago, so long that I can't remember for what need, I wanted to try steam bending. What I was able to read at the time talked about the need for large, solid steam boxes.  Your plastic wrap solution would have worked for me. Great idea. Oh, I like your home-brew boiler too
      This post was edited by Jon Radder at July 31, 2020 10:54 PM EDT
      www.cvsry.com www.cvsry.com
    • August 1, 2020 8:34 AM EDT
      • Posts
        323
      • Thanks
        11
      • Thanked
        10
      The plastic wrap really did not work well.  High failure rate.  What DID work was an aluminum dryer vent line. 4"diameter and expandable.  I should write this up so others are not misled
    • August 1, 2020 9:25 AM EDT
      • Peoria, NW of Phoenix, Arizona
      • Posts
        1,563
      • Thanks
        288
      • Thanked
        370
      I have seen people using a 4" plastic pipe as the steaming vessel for wood. most home centers carry the black drainage pipe in 3 or 4" by 10' lengths.
      Butt Modeler #2
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
