Forums Power and Sound Electronics
  • Topic: ESU LokSound 5 XL Sound Decoder Smoker Install
    Back To Topics
    (0 rates)
    • January 21, 2020 8:41 AM EST
      • McLean, VA
      • Posts
        196
      • Thanks
        2
      • Thanked
        23
      For ESU 5 XL Decoder Experts - I'm installing my first ESU 5 XL into a person's LGB 2018D Mogul which is complete.  I've also installed an LED in the headlight and a Massoth Firebox Flickering Light Module.  Now I want to install a Massoth DCC Pulsed Smoke Unit.  I can't tell from reading the 5 XL Instruction Manual how to set up a pulse output that's pulses in sync with the locomotive's speed/chuff rate.  Can someone advise where to connect the two wires from the Massoth unit and the other adjustments needed on the 5 XL?
      I've installed several Massoth DCC Pulsed Smokers onto Massoth DCC Decoders.  If you're not familiar with the Massoth Pulsed Smokers, there are two ways for it to receive pulsed inputs:  From a DCC decoder, or, from a hall sensor.  If the 5 XL can't produce a pulse input to the smoker, I'll have to then install a hall sensor unit into the Mogul.
      Thanks
      Tom
      Tom White
      LGB Railfan - LocomotivesPro
      https://www.olddominionrailways.com/
    • June 14, 2020 8:54 AM EDT
      • McLean, VA
      • Posts
        196
      • Thanks
        2
      • Thanked
        23
      I got it solved.......got some help from a long-time ESU large scale decoder user/installer.......the Massoth Pulsed Smoker now works great with the ESU 5 XL.
      Tom White
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
