  • Topic: Travis's Mik challenge 2019
    Back To Topics
    (0 rates)
    • February 27, 2019 3:16 AM EST
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      All done......
    • February 27, 2019 8:18 AM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      WOW   That turned out great, Travis. Very impressive.
    • February 27, 2019 8:39 AM EST
      • Easton , Massachusetts
      • Posts
        4,614
      • Thanks
        2,218
      • Thanked
        634
      I have to agree with Dan....
       My u-tube  My Vimeo
    • February 27, 2019 9:09 AM EST
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
      Nothing quite like going from a few piece on the table saw to a masterpiece with nothing in between. That came out excellent.
    • February 27, 2019 10:13 AM EST
      • Vail, Az
      • Posts
        5,431
      • Thanks
        1,963
      • Thanked
        1,363
      Very nice, I'm glad you were able to finish yours.
      John
    • February 27, 2019 10:17 AM EST
      • Cape Cod,
      • Posts
        3,050
      • Thanks
        157
      • Thanked
        267
      That is a great looking water tower Travis.
      What did you do to make the spout?
    • February 27, 2019 10:33 AM EST
      • Posts
        4,614
      • Thanks
        2,218
      • Thanked
        634
      Hopefully he brings it to York so all can see ....
       My u-tube  My Vimeo
    • February 27, 2019 1:09 PM EST
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      Todd, it is from a old piko tower or some other kit. I do want to make another spout for it...
    • February 27, 2019 2:21 PM EST
      • Ormond Beach, Fl. 32174
      • Posts
        1,093
      • Thanks
        3
      • Thanked
        520
      Travis, your water tower really turned out nice, good job, Bill
    • February 28, 2019 4:41 AM EST
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      I will try to get some more photos of it from different angles...
    • February 28, 2019 10:31 AM EST
      • Posts
        1,093
      • Thanks
        3
      • Thanked
        520
      water tank spout
      Actually I think you will find it is from an aristo craft water tank, and if you want a tapered one, other than buying one I suggest you try the heated cvpc pipe that I sent you directions during the build, works and looks great, but I don't see any problem with the 1 you've got, some times it's just best to leave things alone. If you check old pictures you will find that there were lots of different styles, I've even see a square one. Like I said I like it very classy, Bill
    • February 28, 2019 2:24 PM EST
      • Posts
        1,093
      • Thanks
        3
      • Thanked
        520
      Travis, here  is a picture I found on pinterest, seems like your spout has good company, it's from the black hills railroad, still in operation I believe
      The Black Hills Central Railroad’s signature ride during the summer season is called the 1880 Train, which runs the entire length of the line between Hill City and Keystone passing through and along the beautiful hills and canyons of the Black Hills Mountains
    • March 1, 2019 3:02 AM EST
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      Bill Barnwell said:
      Travis, when I did mine I used a piece of 1/2" cvpc pipe secured the top to a counter and attached a large pair of vice grips to the bottom then heated it with a heat gun and as I heated itwater tower spout began to stretch and taper, when it got about to the size I wanted I sprayed it with a water bottle to stop the reaction. then just cut it to length and section the end with left over pieces. later added evergreen strips and chain, worked great and I saved $10 from not buying one from evilbay, Bill
      Bill, could you possibly get some close up pics of the spout?. Thanks ....
    • March 1, 2019 11:38 AM EST
      • Posts
        1,093
      • Thanks
        3
      • Thanked
        520
      spout upper right
      spout left
      spout centerTravis, the rings around the spout are evergreen strips, the eyelets holding the chair are brass screw in ones from hardware store and chain is brass saved from a model ship from back in the 6oths, don't throw anything away you might need, I had taken the time to put rivet detail on the top side of the tube, which you can see the bumps in the left side shop, with archer rivet decals but it really was a waste of time being as you cant see them when the spout is up. Mounted the spout by filing a grove perpendicular to the length and gluing a small piece of hollow styrene across it and securing with a bold and it does pivot. Need any thing else let me know, Bill  Oh the handle is a piece of bent paper clip
      This post was edited by Bill Barnwell at March 1, 2019 7:49 PM EST
    • March 1, 2019 1:53 PM EST
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      Bill, when it stretched were you pulling it with the vice grips or does it naturally do this when exposed to high heat?...
    • March 1, 2019 3:24 PM EST
      • Posts
        1,093
      • Thanks
        3
      • Thanked
        520
      Travis, they were pretty big vice grips that I used and I did so because I was afraid that if I tried to do it by hand it wouldn't be straight and by hanging with a weight on the bottom it would stretch more uniformly which it did. So to refresh. I anchored the top to the side of a cabinet (could use a ladder) and let about a 1 foot piece of cvpc hand vertically and attached a pair of vice grips to the bottom of the pipe, then heated the pipe uniformly up and down and around with a heat gun and when the tubing reached a bendable temperature it started to stretch and as it did it became elongated. Went it reached a size that looked right I sprayed it with a water bottle to stop the process. I might mention that went it started to stretch it went pretty fast. So the worse thing that can happen is you'll have to do it over and use another piece of 25 cents worth of pipe. I got lucky and was able to get it first time. After cooling I cut it at the small end at about a 45 degree angle and then took the cut piece and rotated it 180 degrees and reattached with super glue after cutting a short piece at 90 degrees off for the tip, being as the 2 pieces with the cut 45 came from the same place/piece the tubing was of the same diameter and required no fitting, then cut the whole to the length I wanted. Good Luck, Bill
    • March 20, 2019 3:54 AM EDT
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      Sean, I may be bringing this to York if you would like to see it...... Will be there Friday and part of Saturday.... Travis
    • March 20, 2019 7:20 AM EDT
      • Posts
        4,614
      • Thanks
        2,218
      • Thanked
        634
      I will not be going .... However I'm sure the rest will like to see it !
       My u-tube  My Vimeo
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
