  • Topic: Travis's Mik challenge 2019
    Back To Topics
    (0 rates)
    • January 30, 2019 4:55 AM EST
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      Still kicking around what to do for a spout........
    • January 30, 2019 11:02 AM EST
      • Ormond Beach, Fl. 32174
      • Posts
        1,085
      • Thanks
        3
      • Thanked
        517
      Travis, when I did mine I used a piece of 1/2" cvpc pipe secured the top to a counter and attached a large pair of vice grips to the bottom then heated it with a heat gun and as I heated itwater tower spout began to stretch and taper, when it got about to the size I wanted I sprayed it with a water bottle to stop the reaction. then just cut it to length and section the end with left over pieces. later added evergreen strips and chain, worked great and I saved $10 from not buying one from evilbay, Bill
    • January 30, 2019 7:51 PM EST
      • Chaco, Paraguay
      • Posts
        2,730
      • Thanks
        329
      • Thanked
        317
      for spouts i got from the garage next door some used spouts from half quart motoroil (or additives) bottles.
      they are tapered a bit more than waterspouts, but i think they will do.
      My Chaosplace ->
    • January 30, 2019 8:28 PM EST
      • Vail, Az
      • Posts
        5,421
      • Thanks
        1,947
      • Thanked
        1,359
      I've rolled them from brass shim stock.
      If you can make a tapered dowel it helps prevent dents. Tin both edges and sweat them together. Running a pounce wheel on the outer edge can simulate rivets.
      edit to correct; tapered
      This post was edited by John Caughey at January 31, 2019 5:13 AM EST
      John
    • January 30, 2019 9:44 PM EST
      • Southern Oregon
      • Posts
        1,925
      • Thanks
        462
      • Thanked
        960
      If you can make a taped dowel it helps prevent dents. Tin both edges and sweat them together. Running a pounce wheel on the outer edge can simulate rivets.
      Excellent information, thanks John
    • February 2, 2019 11:14 PM EST
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      Water tower project came to a abrupt halt tonite.... Band saw tire on the pulley flew apart the keeps the blade tracking true....... So I will finish what I can and go from there. Need it to build the roof and cap...
      This post was edited by Travis Dague at February 2, 2019 11:14 PM EST
    • February 3, 2019 11:52 AM EST
      • Vail, Az
      • Posts
        5,421
      • Thanks
        1,947
      • Thanked
        1,359
      Oh man, that's too bad. I was lucky my tires went bad before breaking.
      I like these folks and really like their resawing blades.
      https://www.highlandwoodworking.com/bandsaws-and-bandsawaccessories.aspx
      John
    • February 3, 2019 12:31 PM EST
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      found a pair of tires for band saw last nite on Amazon. Also gonna replace the bearings while it is apart.... Parts wont be here til next Thursday . Oh well, always fun watching you guys build along....
    • February 3, 2019 5:56 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Well, Travis, I hate that. But I am still expecting and looking forward to seeing the tank finished
    • February 4, 2019 12:21 AM EST
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      Well I am temporarily back in the water tower business. I decided to go ahead and build the top with the stuff I had already cut before the band saw took a dump on me. Got the parts ordered but wont be here in time to get it repaired before this ends. So I will finish as much a possible and finish it after the challenge ends.. I will post pics a little bit later tonite.
    • February 4, 2019 8:46 AM EST
      • Smoggy L.A., Left Coast
      • Posts
        7,608
      • Thanks
        158
      • Thanked
        289
      Shoot Travis, that blows... good luck with getting the parts.
      Have fun with your trains
    • February 4, 2019 3:31 PM EST
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      So here is what I have done from last nite.....
       Will post more later.........mow off to work for the day..
    • February 4, 2019 4:39 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Nice start on the top, Travis.
    • February 4, 2019 6:46 PM EST
      • Easton , Massachusetts
      • Posts
        4,609
      • Thanks
        2,199
      • Thanked
        633
      Good choice on what you're drinking to stay hydrated..
      NO not the Titebond III glue...
      This post was edited by Sean McGillicuddy at February 4, 2019 6:49 PM EST
       My u-tube  My Vimeo
    • February 5, 2019 4:18 AM EST
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      More photos of the roof soon to have shingles.....
      This project is not gonna be done by the deadline After starting a week late and working weekends. Just thought I would build along with you guys for fun. Always enjoy the stuff we all come up with...So when I can get time to cut the bottom to fill in the void where the roof over hangs then I can install the fascia. Then comes the shingles.......Thanks for checking in...
    • February 5, 2019 8:56 AM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Nicely done, Travis.
    • February 10, 2019 12:30 AM EST
      • Ohio
      • Posts
        1,005
      • Thanks
        184
      • Thanked
        63
      Band saw parts came today.. Woo Hoo.. So now I am trying to get as much done as possible. Started the shingle roof. Should have it done tonite. Then onto more details...... Pics coming later.......
    • February 10, 2019 1:47 AM EST
      • Vail, Az
      • Posts
        5,421
      • Thanks
        1,947
      • Thanked
        1,359
      Don't worry about pics until you need a break, we can wait a bit, if necessary!
      John
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
