  • Topic: Mik 2019: McGillicuddy's Building Supply - Jon R.
    Back To Topics
    (0 rates)
    • January 25, 2019 6:46 PM EST
      • Southern Oregon
      • Posts
        1,969
      • Thanks
        520
      • Thanked
        1,026
      Yea pricey,
      Last time I checked it about 7-8 years ago it was about 300$ per sheet plus shipping. If I remember it would have been cheaper to drive to Sacramento and back to get it (300 plus miles) than to pay the shipping.  Used Blue foam building insulation instead
    • January 25, 2019 6:50 PM EST
      • Posts
        14,851
      • Thanks
        2,806
      • Thanked
        1,642
      Jon Radder said: That is the battle raging in my head at the moment!
      This is good !
    • January 26, 2019 2:37 AM EST
      • Kailua, HI
      • Posts
        870
      • Thanks
        572
      • Thanked
        638
      Jon and Rick,
      Thanks.  I'll look for the pink and blue stuff!
    • January 26, 2019 8:47 AM EST
      • Posts
        13,754
      • Thanks
        1,487
      • Thanked
        1,093
      I'm getting hung up on windows.  Many of these early industrial buildings had their original windows replaced with plate glass and extruded aluminum frames. Thast was the case with my inspiration building.  I've not been able to find a good picture with original windows.  This one just doesn't have enough detail for my idea...
      What I WANT to do, is find an interesting photo of an early window style and size it to fit my openings; print the photo in black & white on vinyl, cutting away the panes, then mounting that on clear acrylic. This will allow a view through what once was to a black & white interior shot mounted an inch or two behind the window.  Looking through the ghost window frame to the ghost interior.
      Finding window pictures is the easy part. Recapturing my Photoshop skills to to square up photos that have been lost to time  is a challenge I have not yet conquered. No worries; shop the Used Window market on the interwebs. They have plenty of straight on shots.  Problem is the finding the right arch shape for the arch top windows.  I tried modifying the drawing to match what I can find, but it just doesn't look right, so I abandoned that idea.
      I guess I'll be spending part of the day today re-learning Photoshop transformation tools.  I recall that there was a built-in function for this purpose and can even visualize the tutorial, but can't seem to find it either. Maybe I should install the tutorial disk and browse around.
      www.cvsry.com www.cvsry.com
    • January 26, 2019 10:04 AM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Jon, I like what you are trying to do with the windows.  Keep plugging away at it, you'll find a way to get what you want. In the meantime, I'll be sitting over here in the corner with my cup of coffee patiently waiting and providing that much needed moral support .  Looking forward to the final product.
    • January 26, 2019 10:21 AM EST
      • Not one of the WannaBe's,
      • Posts
        5,888
      • Thanks
        1,620
      • Thanked
        763
      Are you going to add the canvas awnings ?
    • January 26, 2019 11:29 AM EST
    • (Moderator)
      • Farmington, New Mexico
      • Posts
        2,578
      • Thanks
        22
      • Thanked
        640
      @ Jon  Photoshop commands to correct images .
      Open photo > Crop to leave extra around subject.
      With image open on screen.
      [Command - A]  Selects all the image
      Do these steps Under the EDIT pop down select:  [EDIT] > [ TRANSFORM] > [ DISTORT ]   Grab the corner box and move to correct the image.
      Hope this helps.
      This post was edited by Dave Taylor at January 26, 2019 1:07 PM EST
      New Mexico­ Northern ­Railroad
      D&RGW ­315 Crew ­member, Fireman
      RRR #4
      Board Memb­er, Durang­o Railroad­ Historica­l Society
    • January 26, 2019 1:04 PM EST
      • Posts
        13,754
      • Thanks
        1,487
      • Thanked
        1,093
      Spent the morning re-learning Photoshop. I think this one will work
      My goal is to have a completed drawing in time to print at work on Monday.  Then I can actually start carving on the real thing.
    • January 26, 2019 1:05 PM EST
      • Posts
        13,754
      • Thanks
        1,487
      • Thanked
        1,093
      No - they didn't survive into the modern era!
    • January 26, 2019 1:07 PM EST
      • Posts
        13,754
      • Thanks
        1,487
      • Thanked
        1,093
      Hope this helps.
      It would have helped if I had checked back here first!  In the crop tool there is a checkbox for Perspective. That automatically does most of the corrections. You can then use Transform to tweak it. I'm not good enough yet to do it with Transform alone.
    • January 26, 2019 5:53 PM EST
      • Posts
        13,754
      • Thanks
        1,487
      • Thanked
        1,093
      OK - It's time for the Architectural Review Board to submit comments.  Other than the main door, which I'm not crazy about, this is the final drawing...
      I also did another full size mock up as a final check of size and fit.  Thought I'd get an idea of the interior simulation while I was at it.  These aren't the final photos or the final lighting; just proving ideas and noticing what will need to be done to achieve what is in my head.  Getting close to what I had envisioned...
    • January 27, 2019 6:57 AM EST
      • Easton , Massachusetts
      • Posts
        4,639
      • Thanks
        2,268
      • Thanked
        648
      Well done .... well done ...
       My u-tube  My Vimeo
    • January 27, 2019 8:46 AM EST
      • West Grove, Pennsylvania
      • Posts
        11,218
      • Thanks
        852
      • Thanked
        1,238
      Ditto....what they said.
      "Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." --Martin Luther King Jr
    • January 27, 2019 10:00 AM EST
      • Nashville, IL
      • Posts
        5,297
      • Thanks
        584
      • Thanked
        393
      Double Ditto....
    • January 27, 2019 10:07 AM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Jon, I am loving what you are doing with the photos in the windows.  That is just way cool.  Now the cherry on top would be a picture of Sean as a kid with his nose pressed up against a window watching the trains go by   Really enjoying watching you put this together.
    • January 27, 2019 11:13 AM EST
      • Posts
        13,754
      • Thanks
        1,487
      • Thanked
        1,093
      Thanks all. Photos in the window is an idea I borrowed from Bruce Chandler.
      Now that I know how I want this to look, I need to work on some more framing to hold it forward off the wall to give some space to view the photos at an angle through the windows.  While I am at it I may add the first few feet of bench work  at the level of the flat board in the mock-up photo.  I cant do any cutting until Monday night after I have the drawing printed on vinyl as my cut pattern.
    • January 28, 2019 7:14 AM EST
      • Chaco, Paraguay
      • Posts
        2,755
      • Thanks
        347
      • Thanked
        346
      if you can, (spacewise) it might be a good idea, to give the whole thing some depth.
      where i used inserted pics or drawings in windows, i put them one inch behind the window openings.
      that gave me enough space, to cover the backside of the wall with alu foil and hang a bulb or two to lighten up the pics.
      My Chaosplace ->
    • January 28, 2019 8:41 AM EST
      • Missouri, It's like Floodsburg, man
      • Posts
        2,836
      • Thanks
        353
      • Thanked
        375
      Jon Radder said: Getting close to what I had envisioned...
      That's a good feeling when a project starts shaping up.
    • January 28, 2019 11:31 AM EST
      • East Brunswick, N J RRR#22
      • Posts
        1,906
      • Thanks
        175
      • Thanked
        233
      In the words of John "Hannibal" Smith, "I love it when a plan comes together."
      "If I ever go looking for my heart's desire again, I won't look any further than my own backyard. Because if it isn't there, I never really lost it to begin with." - L. Frank Baum
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
