  • Topic: Mik 2019: McGillicuddy's Building Supply - Jon R.
    Back To Topics
    (0 rates)
    • January 18, 2019 10:50 PM EST
      • Pleasanton, CA
      • Posts
        1,166
      • Thanks
        1,349
      • Thanked
        907
      Thanks for showing us all this experimentation. Very helpful!
    • January 18, 2019 11:10 PM EST
      • Post Falls, Idaho
      • Posts
        8,275
      • Thanks
        2,364
      • Thanked
        1,298
      Jon,
      I really like the use of photos for the background scene even in and out of the shop. I would have never thought of that. And I like the idea of this being an elevated track. All unique ideas to make a very cool scene.
      I think your execution is coming along nicely
    • January 19, 2019 1:07 AM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Jon, the backdrops totally change the scene.  The inside photo really brings it all to life.  And as Jim stated, thanks for sharing your experimentations with everyone.  I'm watching and learning.
    • January 19, 2019 8:32 AM EST
      • Posts
        13,621
      • Thanks
        1,387
      • Thanked
        994
      To me, sharing it what it's all about. Glad you are enjoying.  It was pretty late last night when I was doing the photo dump and I forgot this close up of the brick making experiment...
      My first plan was to beat the foam up some with a wire brush for texture, but this particular density of foam is looking pretty good with no help at all.
      I have a mini-router attachment for my Dremel, but it's at work locked in my toolbox - I keep forgetting to bring it home to try cutting the big detail lines with it. I can't remember the smallest bit I have and the dust produced by cutting this stuff is awful - but I still want to see what I can do with it.
      www.cvsry.com www.cvsry.com
    • January 19, 2019 10:45 AM EST
      • Peoria, NW of Phoenix, Arizona
      • Posts
        1,518
      • Thanks
        274
      • Thanked
        354
      I was going to build my facade building from Coroplast, but now you have me thinking about getting a sheet of this to build with. I really like the way this is turning out and Rick Marty's picture shows this stuff can live outside. Has anyone tried using a mortar mix on the outsided to give it a little more protection? Thanks Jon, great build. Now to find some off time to think about starting.
      This post was edited by Pete Lassen at January 20, 2019 9:15 AM EST
      Butt Modeler #2
    • January 19, 2019 1:24 PM EST
      • Waverly, Alabama
      • Posts
        2,021
      • Thanks
        786
      • Thanked
        793
      Pete Lassen said:
      I was going to build my facade building from Coroplast, but now you have me thinking about getting a sheet of this to build with. I really like the way this is turning out and Rick Martu's picture shows this stuff can live outside. Has anyone tried using a mortar mix on the outsided to give it a little more protection? Thanks Jon, great build. Now to find some off time to think about starting.
      Pete, I am curious how a mortar mix over the foam would weather.  I've actually built quite a bit of structures out the foam and covered it with a non-sanded grout mixed with some paint but they are inside in my son's bearded dragon terrarium.  It has held up well to constant little feet traffic but I have no idea if would last outside in the elements.
    • January 19, 2019 2:37 PM EST
      • Posts
        13,621
      • Thanks
        1,387
      • Thanked
        994
      The foam I am using is called SignFoam. It is a closed cell high density urethane foam. Website: http://www.signfoam.com/  It is much more dense than the insulation board you buy at the big box stores. I've used that too, but this stuff is designed for carving or machining and since we tend to have "drop" pieces at work that would usually go in teh dumpster I grab a pieces when I have a need.
    • January 19, 2019 5:43 PM EST
      • Missouri, It's like Floodsburg, man
      • Posts
        2,826
      • Thanks
        341
      • Thanked
        372
      Jon Radder said:
      That print came home with me and was mounted on some plastic scrap. It will set the background scene.  I think the door into to McGuillicuddy's will now be above grade - second floor maybe, and the track leading in a bridge or a trestle.  Scene is really coming together in my head. Now if I can just execute...
      That could be a most visually interesting scene with its various layers.
    • January 19, 2019 5:46 PM EST
      • Kailua, HI
      • Posts
        814
      • Thanks
        522
      • Thanked
        572
      This is really cool!
    • January 19, 2019 6:19 PM EST
      • Easton , Massachusetts
      • Posts
        4,608
      • Thanks
        2,198
      • Thanked
        632
      With this pic ..  the building behind the box car is saying that you need to have raised pieces ... like that building ..
       My u-tube  My Vimeo
    • January 19, 2019 6:22 PM EST
      • Posts
        4,608
      • Thanks
        2,198
      • Thanked
        632
      Window sill .. the arches that go from window to window..  And the freight ... entrance/ door needs some thing spectacular ..
       My u-tube  My Vimeo
    • January 19, 2019 6:23 PM EST
      • Posts
        4,608
      • Thanks
        2,198
      • Thanked
        632
      Were is Ray when you need him ..
       My u-tube  My Vimeo
    • January 20, 2019 1:02 AM EST
      • Posts
        13,621
      • Thanks
        1,387
      • Thanked
        994
      Sean - If you are saying the front should not be flat; I completely agree.  The sills will stick out, and maybe the 'keystone' piece above the freight door will be raised as well. The bottom will now extend down even with the bottom of the roadbed on a block or stone foundation. I drew block, but am thinking of changing it to leaning toward cut stone.
      The arches; if executed properly will give the illusion of depth with very little relief.  I have been working all day on the drawing/cut template. It has gotten a lot better with larger brick and more pronounced detail lines. No pic until it's one. Maybe Sunday night. Now I need sleep.
    • January 20, 2019 10:02 AM EST
      • Posts
        1,518
      • Thanks
        274
      • Thanked
        354
      Jon I am guessing one sheet would bust my $30.00 budget, maybe the only way for me to get a hold of some would be dumpster diving at a sign shop, so back to the coroplast design.
      Butt Modeler #2
    • January 20, 2019 10:51 AM EST
      • Posts
        13,621
      • Thanks
        1,387
      • Thanked
        994
      I'm sure it would.  Having first pick of what gets tossed is definitely an unfair advantage. I'll forfeit 10 points to y'all :D
      Worked on the drawing until 2AM. There is not enough coffee on the planet for me to go back to it this morning!
    • January 20, 2019 12:52 PM EST
      • Posts
        13,621
      • Thanks
        1,387
      • Thanked
        994
      I can no longer focus my eyes. All I see is random black and white rectangles.  I think I need a break!  Probably 6 hours staring at this making everything symmetrical and getting all the brick drawn up.  Lots of copy and paste, but man there is a carpload of brick!!!
      Still undecided on the foundation and fascia - but brick detail is done...
      I have some of the foam that is already shaped like a corbel - I'm going to try slicing a few from that piece today. Staying off the computer for the rest of the day.
    • January 20, 2019 1:23 PM EST
      • Cape Cod,
      • Posts
        3,048
      • Thanks
        157
      • Thanked
        267
      The photo background looks great!
      If you have time you could put a sidewalk in front of the building by attaching a 2-3" piece of wood along the front and then add a few trash barrels pallets, a news stand? shoe shine?  or if your building is in a seedy section of town a hobo or 2 passed out drunk.
    • January 20, 2019 6:23 PM EST
      • Posts
        13,621
      • Thanks
        1,387
      • Thanked
        994
      Just to make Sean happy, I started seriously thinking about protruding details. I had this "drop" from work. It is the outside of a CNC router cut for a sign shape...
      We made that sign a few months ago. I knew that shape would be good for something   Now is when I wish my band saw wasn't broken...
      Trying to slice this stuff with the razor saw was none too accurate as the blade tends to wander. Hopefully I can power sand the resulting pieces flat. I'm thinking I need to open up the center - how I'm still working on.  The idea in my head is some type of decorative stone cornice held up by stone or wood corbels.  And, since I am now extending below RR grade I have room for a door. The original structure had a plain man door on this face. The ornate main entrance was around the corner....
      I need to see if I can work something like that in with maybe a few parking spaces for die cast cars. The road could duck under the track with a low-clearance opening. There is no way I am going to carve anything as ornate as the corbels on that entry, but I could do a little simpler - this done with a Dremel and sandpaper as a test...
      That test was made using several tools before bringing out the Dremel. The Dremel alone would have been a smoother cut more like the one on the right.
    • January 20, 2019 8:33 PM EST
      • Posts
        14,778
      • Thanks
        2,735
      • Thanked
        1,607
      David Marconi,FOGCH said:
      Dan I wasn't going too fr as the prices were the $4,000.00 - $5,000.00 type.
      I think you a little bit low. Perhaps add about another 10k onto that and then you are talking.
    • January 20, 2019 10:44 PM EST
      • Posts
        13,621
      • Thanks
        1,387
      • Thanked
        994
      I said I was staying away from the computer, didn't I?  I lied....
      Still working on how the door will look - this is just a size test / placeholder.
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
