Forum Sponsorsss
Forums General General Discussion
  • Topic: Aristocraft BNSF Dash 9 Motor Failure
    Back To Topics
    (0 rates)
    • September 9, 2017 6:52 PM EDT
      • Carlsbad, CA
      • Posts
        6,893
      • Thanks
        95
      • Thanked
        387
      We have learned the hard way about split shafts in Z scale, where the motors not only cannot be bought, but the people that have them want (and get) $100 each for them.
      Pull the gears off with a puller (heat is NOT an option on a 5mm diameter motor!!
      Everything seems cool... then press the gears on, and the shaft recedes into the housing... split shaft motor, but no way to tell before.
      Apparently shaft is inserted into end housing, then gear pressed on, and then half shaft pressed into plastic "center"...
      My GUESS is these (Aristo) motors have a continuous single shaft.
    • September 11, 2017 7:35 PM EDT
      • E. Helena , Montana
      • Posts
        271
      • Thanks
        8
      • Thanked
        24
      Gary,
      I want to extend my sincere, "Thank You!" from all of us at Imagination Station Kids On Track for graciously donating the motors needed for repairs. I know a lot of kids will enjoy running this BNSF Dash 9 and our Pan Am Railways SD45 which both had front drive block motors with bent shafts. (front motors only) The Pan Am was not to bad but still had a front motor with a bent shaft which we will now replace also.
      You know what's interesting is that the good motors spin a little more free than the motors with bent shafts, even though the shafts aren't bent bad. Amazing how just a small amount of bend in the shaft causes so many issues. Wish we could save the motors since they still run so well. Oh well!
      This will fix all of our problem locomotives and once again have everything running, once Barry is finished.
      Oh, thanks for removing the plastic hex ends. I don't know how you amazingly did that?
      Thanks for everything Gary.
      Incidentally, you pack things professionally like I've never seen.
      With your packing, you could probably drop it from an airplane without an issue!
      Greg,
      I believe your correct in as the shaft goes all the way through the motor but I think we'll know more once Barry works on it.
      I sure won't try it myself. There are some things I just don't trust myself with.
      Thanks, Ken
    • September 11, 2017 8:33 PM EDT
      • Carlsbad, CA
      • Posts
        6,893
      • Thanks
        95
      • Thanked
        387
      What is really bizarre is I have never seen nor heard of a motor with a bent shaft in the prime mover motor blocks.
      Is it possible these locos were dropped? Had they ever been opened before?
      In any case, great you problem is solved and I've learned a new thing to look out for.
    • September 11, 2017 9:22 PM EDT
      • Posts
        271
      • Thanks
        8
      • Thanked
        24
      No, never opened. That part I am sure of, however, I am not sure if they were ever dropped in shipping. The boxes looked ok biut one thing they have in common is that they came together in the same shipment from Aristocraft directly.
    • September 13, 2017 5:11 PM EDT
      • YYC, CANADA
      • Posts
        574
      • Thanks
        27
      • Thanked
        7
      "...our Pan Am Railways SD45 which both had front drive block motors with bent shafts. (front motors only) The Pan Am was not to bad but still had a front motor with a bent shaft ."
      Interesting.  Maybe time to finally open our factory fresh/direct from AC units,  and chk this out .... or just bookmark this thread !  :)
      " G-Gauge may not RULE, but it  GROWS  on Ya !! "    djc'99
    • September 13, 2017 5:36 PM EDT
      • Posts
        271
      • Thanks
        8
      • Thanked
        24
      Which units do you have Doug?
      Ken
    • September 14, 2017 5:37 PM EDT
      • YYC, CANADA
      • Posts
        574
      • Thanks
        27
      • Thanked
        7
      Pan-Am !
      When I do finally get around to opening and if finding the same problemo (as you found) I might just have an opinion of the factory in their waning moments for AC  ;)
      This post was edited by Doug Cannon at September 14, 2017 5:39 PM EDT
    • September 15, 2017 12:28 AM EDT
      • Posts
        271
      • Thanks
        8
      • Thanked
        24
      Yea, let's hope they're ok. I haven't really had a huge amount of problems with these drives with these exceptions but as you may know, they like to be kept oiled and I drill grease holes in my gearboxes so I never have to take the drive/gearboxes apart again. I have gotten pretty good at working on this type of drive block but I am still trying to learn more and this post has helped a lot.
      Hope your locomotives are ok.
      Let me know if I can help!
      Ken
    • October 4, 2017 2:47 AM EDT
      • Posts
        271
      • Thanks
        8
      • Thanked
        24
      Gary, Forum Members,
      Our BNSF locomotive is now operational again thanks to Gary and his gracious donation of motors.
      We at Imagination Station Kids On Track and the kids and families who enjoy operating the trains would like to extend our thanks to Gary, largescalecentral.com, Barry's Big Trains and everyone else who contributed (including advise) to get this locomotive and our Pan Am Railways SD45 up and running again. I am sure the public will enjoy these locomotives for years to come. I apologize to everyone for not posting photos of the motors after Barry removed the old brass hex ends and reinstalled them on the motors Gary supplied but my smartphone seems to have a lot of problems posting photos here, every single time I attempt it.
      Gary, Members,
      Here is a less than well done video that shows the locomotive in operation again.(below)
      We did have another couple videos with this locomotive in them and you can hear the difference before the failure and this video after the repair. These videos are on our channel also.
      Barry said that the motors were also arcing heavily and we're pretty burnt up in addition to the bent shafts. It's literally amazing they lasted as long as they did.
      Gary, I didn't mention your name on the You Tube video without your concent but if you would like it in the title, I'll be glad to Change it for you. Just let me know.
      Thanks everyone! Ken
      https://youtu.be/CJtutP_5sC4
      Imagination Station Kids On Track Model Railroad And Train Safety Program, E. Helena, MT
      This post was edited by Ken Mathews/Imagination Station Kids On Track at October 4, 2017 3:01 AM EDT
    • October 4, 2017 7:03 AM EDT
      • Easton , Massachusetts
      • Posts
        3,505
      • Thanks
        577
      • Thanked
        143
      Glad to hear it !
      This post was edited by Sean McGillicuddy at October 4, 2017 7:04 AM EDT
       My u-tube
    • October 6, 2017 7:11 PM EDT
      • Posts
        271
      • Thanks
        8
      • Thanked
        24
      Greg, Gary,
      Barry said that he found the original manufacturer of the Aristocraft SD45 and Dash 9 motors. As hard as this was to believe his research found that these motors are originally built and ordered from Mitsubishi Motor Company, electronics division. They are the exact same motor used in Bachmann units now and are available to this day but without the brass or plastic hex ends. Wether there is more windings on the Aristocraft than the Bachmann still remains to be seen (he is still checking) but they are from that manufacturer with the same voltage and amperage draw.
      Just thought you'd like to know what Barry said and what his research found out through motor code numbers and manufacturing id's.
      Thanks for the help!
      Ken
      This post was edited by Ken Mathews/Imagination Station Kids On Track at October 6, 2017 7:17 PM EDT
    • October 6, 2017 8:35 PM EDT
      • Carlsbad, CA
      • Posts
        6,893
      • Thanks
        95
      • Thanked
        387
      I think that the manufacturer is Matsushita or Mitsui not Mitsubishi. I have never seen small motors like that from Mitsubishi.
      But the motor that is pictured on page 1 is a different manufacturer, and the part number matched exactly. I gave all the links including the manufacturer.
      Over the years, Aristo did change suppliers, and even had a batch of counterfeit motors!
      Here's your picture of the LD5FN motor.... I can't find that part number from Mitsubishi, love to see a link.
      (not trying to be argumentative, but I even gave a link that showed that Aristo was a customer of the manufacturer for that part number motor... pretty darn conclusive)
      Rooster, what the heck are you talking about? If you are serious, please re-read my post where I give complete factual information on the motor and even who bought them.
      This post was edited by Greg Elmassian at April 21, 2018 5:22 PM EDT
    • October 6, 2017 8:45 PM EDT
      • Post Count ,PA ,
      • Posts
        12,108
      • Thanks
        628
      • Thanked
        508
      Greg Elmassian said:
      I think that the manufacturer is Matsushita not Mitsubishi.
      Factual quotes "only" please so we may help the enthusiast>
    • October 6, 2017 11:49 PM EDT
      • San Mateo, California
      • Posts
        172
      • Thanks
        28
      • Thanked
        53
      I believe Matsushita is the parent company of Panasonic and Japan Victor Company (JVC).
      If a motor is marked with an "M" like symbol,
      Mabuchi Electric Motors
      Then it would seem to be a Mabuchi Motor like the SD45 motor that shown on George Schreyer's web site.
      SD45 motor
      See Mabuchi Motor Designations and Their Meanings
      -Ted
    • October 7, 2017 12:20 AM EDT
      • Posts
        271
      • Thanks
        8
      • Thanked
        24
      Ok?? Now I'm a bit confused. I wish Barry had his computer up and running. He might be better with his analization than myself.
      You could be right in manufacturer name difference but I'll ask him again.
      If Aristocraft had changes in motor suppliers, I wouldn't have ever known until now especially If some were counterfeit. I am certainly not saying anything mentioned here isn't accurate, I just am going on what I am told and hoping there's some legitimacy to it.
      Appreciate the information and I'll share it with Barry.
      Maybe I misunderstood.
      Thanks, Ken
    • October 7, 2017 3:14 AM EDT
      • Carlsbad, CA
      • Posts
        6,893
      • Thanks
        95
      • Thanked
        387
      Sorry, the suspected counterfeit motors were in the GP40 and it's my theory, no proof other than circumstantial.. was just trying to convey that over it's history theres been a lot of different things that have happened.
      I guess you did not look at my links where I showed the part number shown on your motor was from a particular manufacturer and I even found that number linked with aristo in a note on a sales order...
      I'm sure you can find many similar motors... but I found the exact motor and part number. But if you found a replacement that is easy to obtain, that's great, do you have the information on the part number, where to order, etc?
      This post was edited by Greg Elmassian at October 7, 2017 3:19 AM EDT
    • October 7, 2017 6:47 AM EDT
      • Posts
        271
      • Thanks
        8
      • Thanked
        24
      Greg,
      This is the list and I see the L5FN and there is a similarity. As far as your number request goes, I'm waiting on Barry to give me that. He is in process of doing research and will let us know next couple days. I guess he wants to be sure he's got it right also.
      Ken
      EN|繁|简|JP|DE|KR
      NICHIBO - DC Motor
      Product News All Products DC MOTOR BLDC MOTOR Product Usage Product Search
      Home > Products > All Products
      All Products
                              Not specify                                                             DC MOTOR        BLDC MOTOR
      Housing ShapeFlat ShapeRound ShapeTypeOperating RangeDiameterLengthView
      7556.0V-36.0V∮42.459 ㎜View
      73612.0V-24.0V∮42.253.5 ㎜View
      RK-6636.0V-36.0V∮3858.1 ㎜View
      551260V-160V∮35.857 ㎜View
      99712.0V-48.0V∮5285 ㎜View
      GRD6.0V-24.0V∮3229 ㎜View
      F-0501.5V-12.0V∮15.526.9 ㎜View
      F-1801.5V-12.0V∮20.432.1 ㎜View
      FK-1303.0V-26.0V∮20.525 ㎜View
      PC-2603.0V-24.0V∮2427 ㎜View
      PC-2803.0V-24.0V∮2430.5 ㎜View
      UC-1301.5V-24.0V∮20.525 ㎜View
      UC-2603.0V-24.0V∮24.227 ㎜View
      UC-2803.0V-24.0V∮24.230.5 ㎜View
      DC-13012.0V-24.0V∮20.425 ㎜View
      DC-2604.5V-24.0V∮24.227 ㎜View
      DC-2804.5V-24.0V∮24.230.5 ㎜View
      RK-2506.0V-24.0V∮2230.5 ㎜View
      FE-2601.5V-12.0V∮2427 ㎜View
      FC-2601.5V-12.0V∮2427 ㎜View
      FE-2801.5V-24.0V∮24.230.5 ㎜View
      FC-2801.5V-24.0V∮24.230.5 ㎜View
      370S4.5V-24.0V∮24.430.8 ㎜View
      GR4.5V-24.0V∮3229 ㎜View
      RF-3101.5V-12.0V∮24.418.4 ㎜View
      RF-3703.0V-24.0V∮24.430.8 ㎜View
      RF-5003.0V-12.0V∮3219.5 ㎜View
      M3N2.4V-24.0V∮27.832.5 ㎜View
      M5N2.4V-24.0V∮27.832.5 ㎜View
      M3FN2.4V-24.0V∮27.832.2 ㎜View
      M5FN2.4V-24.0V∮27.832.2 ㎜View
      L3N2.4V-24.0V∮27.837.8 ㎜View
      L5N2.4V-24.0V∮27.837.8 ㎜View
      L3FN2.4V-24.0V∮27.837.5 ㎜View
      L5FN2.4V-24.0V∮27.837.5 ㎜View
      J33.6V-24.0V∮27.846.6 ㎜View
      J53.6V-24.0V∮27.846.6 ㎜View
      J3FN3.6V-24.0V∮27.846.5 ㎜View
      J5FN3.6V-24.0V∮27.846.5 ㎜View
      M-AA6.0V-24.0V∮27.832.5 ㎜View
      M-BB6.0V-24.0V∮27.832.5 ㎜View
      L-DD6.0V-24.0V∮27.837.8 ㎜View
      H3SN3.6V-24.0V∮3650.1 ㎜View
      H5N3.6V-24.0V∮36
      These are prev. ref. Id's.
      This post was edited by Ken Mathews/Imagination Station Kids On Track at October 7, 2017 7:01 AM EDT
    • October 7, 2017 12:07 PM EDT
      • Carlsbad, CA
      • Posts
        6,893
      • Thanks
        95
      • Thanked
        387
      Yep, that is the manufacturer I found based on the part number from your picture... Like I said, I found a record of Aristo-Craft purchasing these.
      Of course, over the years, Aristo bought different components for the same locos, and changed parts... if you can find a mitsui or matsushita motor with the same specs, that's another avenue for parts, since they are more commonly imported.
      I'm afraid that the double-ended shaft option does not seem as common from my research.
      Perhaps Bachmann will see fit to make the 3 axle blocks again... and then our parts situation will be rectified.
    • October 7, 2017 5:10 PM EDT
      • Posts
        271
      • Thanks
        8
      • Thanked
        24
      Yea, it sure would be nice if Bachmann, as you said, would reproduce the 3 axle drive and even better if they could get rights to reproduce the Dash 9 and SD 45, (or design something new) They seem to be making other Aristocraft items like the Eggliner, etc. not to mention the fact that since they have never produced a large modern diesel, it would be nice to see a reproduction or new product along those lines.
      I think a lot of that previous stuff was all made in the same factory, over in China anyway.
      I do believe however that the Dash 9 was one of the most popular locomotives built by Aristocraft but then again the SD 45 was well liked also.
      It'll be interesting to see what comes down the road!
      Ken
    • October 7, 2017 11:35 PM EDT
      • Posts
        271
      • Thanks
        8
      • Thanked
        24
      Greg, Gary,
      Barry contacted me back and wishes to extend his apologies for not finding a part number for the Bachmann trolly motor that matches the Aristocraft 3 axle drive block motors can size, shaft size, voltage and amperage, contacts, etc. and he believes you may be correct in the fact that Mabuchi may be the actual manufacturer of this motor, among others. He believes (if RPM and torque of the Aristocraft motor and Bachmann trolley motors match) that the Bachmann trolley motor would be an adequate replacement for the motors in the Aristocraft 3 axle drive. If anyone has the capability to test these 2 things and see if they are similar we may have a motor that can replace damaged motors in the Aristocraft drive block. Incidentally, the Bachmann trolley motor has a double shaft also.
      Here is Barry's comparison.
      Aristocraft LD5FN 4412.OY
      Volts Amps
      10-------.20
      20-------.23
      25-------.23
      Shaft length, .700
      Shaft diameter, .088
      Some motor shafts were shorter at .555 due to Aristocraft using different manufacturers of their motors.
      Bachmann Trolley Motors (4 Motors Tested)
      Volts Amps/Motor 1 Motor 2 Motor 3 Motor 4
      10/ .20 .20 .20 .20
      20/ .20 .25 .20 .20
      25/ .22 .28 .20 .21
      Shaft length, .700
      Both housings are the same except for face plates/contacts are identical.
      Barry says, if RPM and torques match, that the Bachmann trolley motor would be an adequate replacement motor for Aristocraft 3 axle drive blocks.
      This may or may not be a future solution for motor replacement but it's definitely promising.
      Feel free to post any further comparisons.
      If you have any further questions for Barry, I'll be happy to ask him and post his answers here.
      Ken
      This post was edited by Ken Mathews/Imagination Station Kids On Track at October 7, 2017 11:53 PM EDT
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
