airwire help
GP38-2 airier drop in and phoenix P8
I tested this earlier this week and everything was great
Today sound works but no lights or movement.
Anrrrrrgggghhhhhh!!!
I tried CV-8 reset but no luck
any thoughts?
thanks in advance
JKS
John
It sounds like loose wires causing a power loss. Start by checking all connections into and out of the board. On the main power check the fuse to the Airwire. Charge the batteries and check those connections as well.
If you can see the board check to see if the LED is green indicating that the board is functioning properly.
John hate to say this but is the switch to the board on? If so like Boomer said is the led on?
cheers
Richard
Are you able to control the sound with the throttle? If the main board isn’t getting power, the P8 will power up and make sound, but you won’t be able to trigger the horn, bell, etc.
I can’t control the p8
thanks guys
will do
works now
sorry for the freak out!
seems to be a wire
thanks for the help!
Don’tcha just love it when a plan works out?
