  • Topic: Mik 2016 Buld Log - Daktah John - CVSRy
    Back To Topics
    (0 rates)
    • February 17, 2016 9:21 PM EST
      • Burke, Virginia
      • Posts
        7,540
      • Thanks
        253
      • Thanked
        919
      I sure hope you're bringing it to York.
      Bruce
      http://jbrr.com/
    • February 17, 2016 9:29 PM EST
      • Posts
        14,868
      • Thanks
        2,814
      • Thanked
        1,644
      Damnation Mr Chandler got page 8!
    • February 17, 2016 10:32 PM EST
      • Posts
        13,754
      • Thanks
        1,489
      • Thanked
        1,095
      I hope I'm bringing ME to York. If I am, then it can ride along
      www.cvsry.com www.cvsry.com
    • February 27, 2016 9:26 PM EST
      • Posts
        13,754
      • Thanks
        1,489
      • Thanked
        1,095
      I've been experimenting with lighting.  I salvaged a bunch of LED modules from a sign we scrapped a few months ago. They don't have any plastic body, just a small PC board with three LEDs and a driver chip. They run on 12VDC.  I temporarily mounted two of them on top of the center beam facing up to reflect off the roof. Two may be a bit too many as the light is a bit hot driven with an 11V battery pack...
      These modules will operate down to about 6VDC and dim as you reduce the input voltage which is unusual for LEDs. I may try driving them with around 9 volts and see how it looks. Here's another angle at full brightness...
      I'd like to light all of my buildings this year (just what I need ANOTHER project). I modified an old computer power supply to run without a computer that I will use to drive LED modules mounted inside my buildings.  I plan to use my track as a power buss since I no longer use it to power my trains.
    • February 28, 2016 10:53 AM EST
      • Smoggy L.A., Left Coast
      • Posts
        7,627
      • Thanks
        170
      • Thanked
        304
      Nice recycling and repurposing,
      Just a general observation about lighting in our hobby. I have been replacing the CFB lights around the house with LEDs. The one thing I don't like about LEDs is that they usually come in that bright blue white color, so I have to make sure the bulbs I get are the yellow soft white color bulbs. I haven't yet seen this softer yellow LEDs filter down into scale fixtures for model railroading. All the LED lighting I have seen across the scales is the blue white lights which work for depicting modern day lighting (post 1960) but if you're modeling earlier your kinda stuck with grain of wheat type lights, which give that yellow light but have a limited lifespan. I hope it's only a matter of time before we see the yellow white LED lighting filter down into something useful for us.
      If anyone knows of any yellow white led products that could be applicable I'd love to hear about them. ;-)
      Have fun with your trains
    • February 28, 2016 11:14 AM EST
      • Posts
        13,754
      • Thanks
        1,489
      • Thanked
        1,095
      @Vic - I agree. The sign service LEDs that I use come in a variety of color temperatures, however when salvaging or intercepting left-overs from the trash I don't get to choose. Most of the signs we build use the bright white (bluish) that you speak of. Running them at a lower voltage does help a bit, but still looks like modern lighting.  That's OK for my RR because I am a modern era scenic line / museum
      @ Korm - I used a similar tutorial from the same site. I had a few issues at first because I didn't have a proper load resistor. I experimented with some nice wire-wound 6.8K's I had; two in parallel for 3.4K, but it was too much and it kept shutting down. The circuit really wants to see 100 Ohms or under - the tutorial suggested 10 Ohms. I had a 100 Ohm 1 watt carbon and that seems to be OK - not getting hot and the supply is happy. Good free power
    • February 28, 2016 7:42 PM EST
      • Pittsburgh, Pennsylvania
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      Vick, they do sell warm white LEDs, both separately and in lighting strips. And you can paint LEDs with glass paint, the type used to simulate stained glass, or Tamiya makes paints used for colouring clear plastic parts like scale model car turn signal lenses. I painted a bright white LED with some amber Tamiya paint, and the light is now a nice, bright, orange colour.
      Shannon car Shops
      Home of the infamous leg lamp
      I.A.R.R.R. Member #12
      and King Butt Modeler
    • February 29, 2016 12:11 AM EST
      • Post Falls, Idaho
      • Posts
        8,284
      • Thanks
        2,370
      • Thanked
        1,318
      The LEDs I used in my MIK build are 3mm warm white. Check out Lighthouse LED for a great selection
    • February 29, 2016 6:13 PM EST
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      The thing is, years ago I bought a bag of bright white LEDs on sale, a 50 count bag. So now I am stuck with more white LEDs then I will probably ever need. And just over a year ago, I bought a string of warm white LED Christmas lights in an after Christmas sale, and I forget if it was a 50 count string or not. So, I should be set on LEDs for a while.
      Shannon car Shops
    • February 29, 2016 8:31 PM EST
      • Post Falls, Idaho
      • Posts
        8,284
      • Thanks
        2,370
      • Thanked
        1,318
      I do like the idea of painting the lenses thought. That is an interesting idea. I know the tamyia paints your referring to.
    • February 29, 2016 9:13 PM EST
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      Devon I did it to my Shay, a bright white LED just didn't tickle my fancy.
      Shannon car Shops
    • February 29, 2016 11:17 PM EST
      • Post Falls, Idaho
      • Posts
        8,284
      • Thanks
        2,370
      • Thanked
        1,318
      Yeah I don't think the bright white would be a no go. I have a bright white in my 2-6-0 and I am afraid it isn't going to be right. I was thinking of some way to  yellow it and I think this will be worth a try.
    • March 5, 2016 10:47 AM EST
      • Posts
        13,754
      • Thanks
        1,489
      • Thanked
        1,095
      For headlights I've standardized on Amber LED's. I bought a couple of these...
      from AllElectronics.com for $1.50 each and have been dissembling them to re-purpose the LEDs. It's not a simple process and the leads are very short but it can be done...
      They are still available here: http://www.allelectronics.com/make-a-store/item/led-155/12-led-amber-lamp-used/1.html
    • March 5, 2016 9:19 PM EST
      • Peoria, NW of Phoenix, Arizona
      • Posts
        1,563
      • Thanks
        288
      • Thanked
        370
      Devon did you post some pictures after you installed the lights on your MIK build? I dont remember seeing any.
      Butt Modeler #2
    • March 6, 2016 9:47 AM EST
      • Post Falls, Idaho
      • Posts
        8,284
      • Thanks
        2,370
      • Thanked
        1,318
      yeah I did
      these are 3mm warm white
    • April 1, 2016 8:52 PM EDT
      • Posts
        14,868
      • Thanks
        2,814
      • Thanked
        1,644
      David Russell said:
      Daktah John said:
       https://www.youtube.com/watch?v=KAsrhd6ujEw
      Bump
    • May 14, 2017 11:29 AM EDT
      • Posts
        13,754
      • Thanks
        1,489
      • Thanked
        1,095
      The Wall Passenger Shelter finally got a permanent base and a place on the railroad this spring; only a year late.  Since these pictures were taken I excavated a bit more under the base to reduce the step height to a nominal scale 8" at the low end. The base was made from a scrap of 25mm Foamed PVC Board salvaged from the trash at work.  Round holes for the vertices were drilled just under size for an interference fit. Joint lines were made with a scribe at 24" intervals. The paint is Benny Moore 1616 "Stormy Sky".
      So, almost a year and a half later I think I can finally call this project done!
    • May 14, 2017 11:59 AM EDT
    • (Moderator)
      • Farmington, New Mexico
      • Posts
        2,578
      • Thanks
        22
      • Thanked
        640
      Well it's about time...     Mik's smiling....
      New Mexico­ Northern ­Railroad
      D&RGW ­315 Crew ­member, Fireman
      RRR #4
      Board Memb­er, Durang­o Railroad­ Historica­l Society
    • May 14, 2017 8:51 PM EDT
      • Posts
        11,131
      • Thanks
        127
      • Thanked
        919
      No, it aint done! It need peoples, and maybe a pigeon or two roosting in the rafters.
      Shannon car Shops
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
