  • Topic: MRC decoders
    Back To Topics
    (0 rates)
    • August 28, 2013 11:36 AM EDT
      • Calgary, Alberta
      • Posts
        48
      • Thanks
        0
      • Thanked
        1
      Has anyone used MRC decoders?
      I have come into a box of different ones.
      The 8 amp models have relays.
      Are these old models?
      AD320 2.5 amp, 2 function
      AD321 3 amp,4 function
      AD322. 8 amp with diesel sound,4 function
      AD324 8 amp, 4 function
      David
    • August 28, 2013 1:53 PM EDT
      • Posts
        360
      • Thanks
        2
      • Thanked
        65
      David - I have a number of the AD322's that I have hacked over the last few years - there are some notes on that decoder on my web page at:
      http://www.trainelectronics.com/MRC_DCC/
      Hope that helps!
      dave
    • August 28, 2013 7:30 PM EDT
      • Calgary, Alberta
      • Posts
        48
      • Thanks
        0
      • Thanked
        1
      I will take a look. Thanks
    • August 28, 2013 11:16 PM EDT
      • Calgary, Alberta
      • Posts
        48
      • Thanks
        0
      • Thanked
        1
      I have found a lot of reviews on the www and it seems these decoders are bottom feeders.
      Most people were not happy with them.
      Maybe I will hook one up and try for myself.
      David
    • August 29, 2013 5:20 AM EDT
      • Eastern Massachusetts
      • Posts
        888
      • Thanks
        3
      • Thanked
        48
      I believe this series had 21 volt ratings, I use them on my 24 volt DCC system and they work, but are old technology and make motors sing.
      For the price I paid for them, they are great.
    • August 31, 2013 10:46 AM EDT
      • Calgary, Alberta
      • Posts
        48
      • Thanks
        0
      • Thanked
        1
      Dan,
      I hooked up an AD-320 to a USA trains motor block and led's for lights and f1, f2.
      Seems to be ok. No motor noise.
      Are you able to read back cv's? I am having no luck with my Massoth 1210z.
      I plan on putting this into an LGB 2-4-0 in place of a lgb 55021.
      David
    • August 31, 2013 10:37 PM EDT
      • Carlsbad, CA
      • Posts
        6,930
      • Thanks
        96
      • Thanked
        392
      I have a bunch of the 322's and about 5 have blown up, looks like the regulator, I got them for $10 each so considered them disposable.
    • September 1, 2013 7:53 AM EDT
      • Posts
        888
      • Thanks
        3
      • Thanked
        48
      I can read back on my Zimo system.
      Is CV 29 set to 2 for 28/128 speed steps and your system at 28 or 128?
      If one is 28 steps and the other is 14 speed steps, read backs will be flaky at best.
    • September 1, 2013 12:26 PM EDT
      • Calgary, Alberta
      • Posts
        48
      • Thanks
        0
      • Thanked
        1
      I can read the decoder with sound but not the decoder without.
      Some the lights work on 14 steps but not 28.
      More trouble than they are worth especially since they are going probably going
      To fail in short order. I will install one in the lgb 2-4-0 for my friend (his choice) and
      See how long it lasts. He is running mts so 14 steps is good for him.
      He has a MRC system that he does not use, maybe I will get it from him and see how it handles
      The MRC decoders.
      David
    • September 2, 2013 7:29 AM EDT
      • Posts
        888
      • Thanks
        3
      • Thanked
        48
      The LGB system is 21 volts if I remember correctly, so the MRC decoder should be OK.
      I have a MTS I system with an engine running the MRC AD324 and no problems with a year of running.
    • September 5, 2013 3:54 PM EDT
      • Carlsbad, CA
      • Posts
        6,930
      • Thanks
        96
      • Thanked
        392
      The problems with the MRC units do not appear to be solely voltage related, I have had several just "lock up" and then usually some component smokes, often the regulator or the output transistor.
      Dave: wow, you really did play a bit with these... what did you use the one you showed for, it was clear it was not DCC, but some motor control and some sound.... like an animation thing?
    • September 5, 2013 5:49 PM EDT
      • Posts
        360
      • Thanks
        2
      • Thanked
        65
      Greg - I used them for a Christmas Trolley layout on the front porch of the house - ran two of them (swapped them out every-other-day) for 32 days - I added my own PIC controller and used the relay and power transistor and sound on the board -
      The program had the units going back and forth for up to 16 hours every day - the track power was 18 volts AC, rectified inside of the trolley.
      Sort of a poor man's DCC!  It worked very, very well.
      dave
    • September 9, 2013 5:08 PM EDT
      • Calgary, Alberta
      • Posts
        48
      • Thanks
        0
      • Thanked
        1
      The MRC decoder hard wired to an lgb interface In place of
      the lgb 55021 would run the motor ( little noise) but not the lights.
      I have spent enough time on this so, back to plan "A" use the correct
      Lgb 55021 decoders. Works fine now.
      David
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
