  • Topic: Thomas is converted to Track Power or Battery Power.
    Back To Topics
    (0 rates)
    • July 18, 2011 12:18 AM EDT
      • Posts
        3,966
      • Thanks
        1
      • Thanked
        90
      I have another Thomas here to convert to battery R/C. Before I do the conversion I wanted to show readers how easy it is to do a simple modification to Thomas so he can run on Track Power or Trail Car battery power. Following are three pics of how I would wire Thomas. Take care removing the body from the chassis. Lift the rear up and push forward to disengage the movable eye levers. Then I drilled a suitable hole in the floor of the chassis. Simply reach under the floor to switch from one to the other. The first pic shows how I unsoldered the two sets of pick up wires from the little pcb on the end of the motor. Then I kept them joined together and added an extension for each colour so they could reach the switch. The joins were covered in heat shrink tube. The thicker black parts. The extensions go to one end of the switch.
      Next I added two new wires from the little pcb on the end of the motor to be connected to the centre terminals of the switch.
      This pic shows how I drilled a hole in the rear crossbeam to allow a two wire connector cable to be fed through and up into the loco. These two wires were connected to the other end of the switch.
      Tuck the wires out of the way and refit the body. To make life simple replacing the little levers for the eyes in the slots on the actuating mechanism, I removed the face and taped the eyes in the middle. Then when the body is back on it is much easier to get the levers in the slots. I hope that helps. I will post the battery R/C + MyLocosound conversion later this week.
      Best wishes,
      Tony Walsham
    • August 23, 2011 9:17 AM EDT
      • Parts Unknown,
      • Posts
        1,428
      • Thanks
        17
      • Thanked
        12
      Tony, is that the Bachmann or old Lionel Thomas?
    • August 23, 2011 5:28 PM EDT
      • Posts
        3,966
      • Thanks
        1
      • Thanked
        90
      Hi Terry.
      Bachmann.
      Best wishes,
      Tony Walsham
    • August 23, 2011 7:43 PM EDT
      • South Central , PA
      • Posts
        15,470
      • Thanks
        3,488
      • Thanked
        1,961
      I want the face!!
    • August 23, 2011 8:54 PM EDT
      • Nashville, IL
      • Posts
        5,401
      • Thanks
        1,306
      • Thanked
        480
      David Russell said:
      I want the face!!
      Son, you could use a new face..... :)
    • August 24, 2011 10:12 AM EDT
      • Deer Park, Washington
      • Posts
        12,598
      • Thanks
        605
      • Thanked
        389
      Knock it off, Rick.
    • August 24, 2011 10:26 AM EDT
      • Your Host in Littleton, MA
      • Posts
        8,124
      • Thanks
        647
      • Thanked
        1,858
      Play nice
    • August 24, 2011 1:15 PM EDT
      • Spokane Valley, Washington St.
      • Posts
        5,728
      • Thanks
        442
      • Thanked
        442
      What's the purpose of the board on the motor?
      Just askin............
    • August 24, 2011 5:05 PM EDT
      • Posts
        3,966
      • Thanks
        1
      • Thanked
        90
      It appears to be the same pcb as used on other locos. I suppose Bachmann put it there to comply with European motor suppression requirements. The PnP locos have the same components mounted on the removable plug.
      Some of the early suppression pcb's mounted on the end of the motors had mis wired 47 µf electrolytic caps which must be removed.
      This one can be left in place when using my new Remote Control Systems (RCS) Professional series ESC's.
      Best wishes,
      Tony Walsham
    • August 24, 2011 8:15 PM EDT
      • Posts
        15,470
      • Thanks
        3,488
      • Thanked
        1,961
      Andy Clarke said:
      David Russell said:
      I want the face!!
      Once again you hurt my feeling's ...please wire some money so I can get out of this jail in Mexico
    • August 25, 2011 4:01 PM EDT
      • Posts
        12,598
      • Thanks
        605
      • Thanked
        389
      David Russell said:
      Andy Clarke said:
      David Russell said:
      I want the face!!
      You in Tijuana or Juarez? It makes a difference on the amount of squeeze I havta bring.
    • August 25, 2011 7:45 PM EDT
      • Posts
        15,470
      • Thanks
        3,488
      • Thanked
        1,961
      Hell I don't know Steve ....but if Tony ain't gonna use the face on that loco I would sure like to have it!
      Know of any DC-3's for rent?
    • August 25, 2011 7:53 PM EDT
      • Posts
        3,966
      • Thanks
        1
      • Thanked
        90
      David me boyo.
      You really need to read properly.;)
      What I wrote was:
      Nowhere did I say I wasn't going to use the face.
      Best wishes,
      Tony Walsham
    • August 25, 2011 7:57 PM EDT
      • Posts
        15,470
      • Thanks
        3,488
      • Thanked
        1,961
      LMAO :)
    • August 26, 2011 10:47 AM EDT
      • Roanoke, VA
      • Posts
        786
      • Thanks
        80
      • Thanked
        279
      David;
      Interesting car in your photo. I'm trying to guess it's purpose. I have a) Scales test car, b) explosives carrier, and c) rooster coop. Am I close?
      Thanks,
      David Meashey
    • August 26, 2011 6:59 PM EDT
      • Posts
        15,470
      • Thanks
        3,488
      • Thanked
        1,961
      Dave Meashey said:
      David; Interesting car in your photo. I'm trying to guess it's purpose. ........ Scales test car,
      Yes but it needs a face! ;)
    • August 26, 2011 7:53 PM EDT
      • Posts
        3,966
      • Thanks
        1
      • Thanked
        90
      You could always BUY a Thomas and take the face out.
      Best wishes,
      Tony Walsham
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
