  • Topic: Bachmann K-27 gets the RCS-BELTROL treatment
    Back To Topics
    (0 rates)
    • October 10, 2010 8:28 PM EDT
      • Posts
        3,966
      • Thanks
        1
      • Thanked
        90
      My latest project is to fit a Bachmann K-27 with RCS-BELTROL R/C equipment, batteries and a Phoenix P8 sound system. Although the owner will not be using track power I decided to use the new RCS-BELTROL # PnP-ADPT kit anyway. This simply plugs into a standard Bachmann/AristoCraft socket and permits any non Plug'n'Play R/C of any brand to be used with the K-27. This is a prototype pcb that I am using until the actual production pcb's are ready shortly. It provides convenient screw terminals with colour coded wiring to ease installation. The wiring was installed into the # PnP-ADPT ready for the # PnP-ADPT to be plugged into the socket.
      The # PnP-ADPT was then plugged into the socket.
      Here it is shown wired into the 5 amp # BTL-PnP5 ESC.
      The white styrene strip glued to the two rear pcb supports is for mounting the Phoenix P8, which is yet to be installed. This is a simple screwdriver install to the RCS-BELTROL sound triggers. To save a lot of mucking around inverting the chuff signal I simply made a chuff timer for the front axle of the front tender truck. The wheel diameter is almost exactly half the size of the drivers so two magnets gives 4 beats per revolution.
      I tested the loco at the weekend on Gordon Watson's layout. I got well over 100' of range using a Spektrum DX5e R/C with really good slow speed running and superb control across the speed ranges. The top speed on 14.4 volts is more than adequate. Bear in mind this is on a dead flat layout and with no load on the loco. Past experience with K-27's has shown me pulling power on grades is not very good. Phoenix shipped the P8 sound promptly but it disappeared for 16 days between the Chicago and Australia. Anyway, the Phoenix P8 sound eventually turned up so I could finish off the installation.
      This P8 is much less complicated to install than the old P5 + P5T. The tiny P8 is mounted on a small styrene sheet glued to the two end stanchions of the PnP socket support. I have four sound triggers plus the chuff. The sound trigger wiring is super simple with regular screwdriver connections. This makes it much easier to select which stick to use for a particular sound trigger. The owner chose to use a Spektrum 5 channel DX5e for control. If a 6 (or more) channel 2.4 GHz R/C system was used, it would be possible for one of the extra channels to be used to control the volume as well. EDITING NOTE. The DEC-ADPT quoted above is no longer made. The RCS-PnP now plugs in directly to the Loco socket.
      Best wishes,
      Tony Walsham
    • October 10, 2010 9:49 PM EDT
      • Curmudgeon at Large, Lynn Haven, FL
      • Posts
        2,318
      • Thanks
        90
      • Thanked
        327
      Tony,
      FYI on the pulling power. I just spent an 8 hour session on our club layout with my K pulling 4 AMS boxcars, 1 AMS tank car, and 1 Bachmann Spectrum Long caboose. The loop I was operating on has an approximately 1.5% grade up to our bridges and then again down to the main level. At 14 volts on the level she drew 1.0 amp steadily. The max on the up grade was 2.0 amps (with marked speed reduction) and was at 0.7-0.8 amp on the down side with slight speed increase.
      Bob C.
      We don't stop playing with trains because we grow old, we grow old because we stop playing with trains.....
    • October 10, 2010 10:37 PM EDT
      • Posts
        3,966
      • Thanks
        1
      • Thanked
        90
      Thanks Bob.
      I have converted about a dozen of them now.
      That confirms what I found. Any steeper than that, really bogs it down.
      Best wishes,
      Tony Walsham
    Icon Legend
  • Topic has replies
    Hot topic
    Topic unread
    Closed topic
    BBCode  is enabled
    HTML  is enabled
Add Reputation
or cancel
Ads by Google
